#7931 |
Bobo,
Is that from a toe kick heater? (under cabinet?) I've installed quite a few of those, and yes they are silent. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#7932 |
I got them from a flea market. I have been told they come from big computers.
I run them at half their rated voltage. Last edited by bobodioulasso; 24th May 2010 at 09:50 PM. |
#7933 |
Most supply caps have snap in lugs, for print boards
But I want to use copper wire So I thought about using this wirewrap method, which should make the connection better and more solid It will still be soldered |
#7934 |
sorry still cant see it
#7935 |
Should work fine, it looks similar to how the caps are wired in my antique Hafler DH200.
Ron
#7936 |
expert in tautology
Tinitus, very good, but overkill. Solder is likely sufficient.
You click on the image, it gets larger... folks... ...but he is using a wire tie, like is done with heavy gauge AC wire on electric poles when tied to insulators (just a smaller scale). _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#7937 |
On my Parallel caps I did it like this, because of the nice color contrast with the copper wire and brass bolts on caps, how ever doesn't always make good contact maybe didn't get all the enamel off the wire or not a good way ?.
#7938 |
Good
![]() Another thing Looking at Panasonic supply caps I find that there are some nice ones with higher capacity and low ESR like say 20milli ohm But some of them have much higher ESR, even in the same range and quality Maybe they are designed for different application I wonder if all builders are aware of that I reckon the higher ESR could result in caps getting quite warm, or ?
#7939 |
Ive used in parallel 11 Mallory 6400 uF 60 vot 45x80mm they not quite fitting for this circuit but they give a nice tone and detail etc to the amp in front of them i have 4 10.000 in serial with ov to earth on them. small caps I suspect have better ESR but using what i had still have 30 6400uF if any one what some ?
NOS. I cant even use them for door stoppers they just roll away. |
#7940 |
bear, Ive just been looking at your site, and the way your power supply done on Symphony amp, its brilliant I'll get some copper I think,
you have to transformers in parallel ? |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
