F5 power amplifier
F5 power amplifier
Old 20th May 2010, 08:36 AM   #7881
chchyong89 is offline chchyong89  Malaysia
Send a message via MSN to chchyong89
the signal and ground is far apart from my transformer :/
here is my simple graphical example of my wiring on the pot.
i will show up the picture later once i get a camera on my hand
Old 20th May 2010, 09:52 AM   #7882
R.I.P.
i think you have three problems, although one or two may be much worse than the third.
First.
The potentiometer body should have a separate wire back to the main Audio Star Ground.
Second.
The wires (green & black) from input to pot should be very close together to minimise loop area. Usually this is done by twisting.
Similarly the red and black wires from pot to amp input should be very close together, again usually twisted.
However, you have L+R+Return as a group, twisting will make crosstalk worse.
Third.
All the mains and secondary AC wiring must have a small loop area. This is to minimise the mains signal that your wiring transmits to the air. This is done by taking pairs of wires that form a flow and return circuit and twisting them together. The DC supply to the boards is +&-&Return. These three wires should be twisted as a triplet to minimise loop area.
Try First, then third, before attempting second.
regards Andrew T.
Old 20th May 2010, 09:54 AM   #7883
william2001 is offline william2001  United States
william2001's Avatar
I guess if I was doing something like this, I would:
- replace all signal wiring with good coax
- remove short jumper from signal ground to pot
- connect mains earth ground to chassis
- route all signal wiring well away from transformer / any primary wiring
- wire from pot shaft to earth ground if necessary
- connect circuit ground to chassis / earth ground in the manner Nelson suggest
Old 20th May 2010, 10:18 AM   #7884
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Drawing
Old 20th May 2010, 10:22 AM   #7885
awc is offline awc  New Zealand
chchyong89
Can you do a drawing coming back the other way, from wall plug and speakers out, showing all "positives / phase" in red, "negatives / -" in black and all "ov's / earths" in green,
it concerns me when you say
1. My F5 is running naked, there is no earth wire from my wall plug
Also you could have a dry joint in power supply caps etc,
mine dose that with my caps connected by copper wire rapped around bolts into caps, so I give them a tap to make contact and hum lessen and go's away further as I move further from speaker and crank the volume up, Its that "sweet spot" Nelson talks about ?
Old 20th May 2010, 11:03 AM   #7886
R.I.P.
Bobo's diagram shows minimum loop area for each pair of flow and return wires. These can be twisted to maintain and average that minimumloop area.
However, in Stereo, there is a problem. The source usually has the RCA phono output grounds connected to each other. That creates a loop in the returns and minimising the Hum Voltage around the ground loop is difficult. The loop area of the interconnect grounds and the two channels of grounding wires inside the amp must all be laid out to minimise loop area. But even this does not remove the Hum Voltage. It merely attenuates it.
regards Andrew T.
Old 20th May 2010, 11:11 AM   #7887
I use this wiring diagram (double mono) in my F5.
I have no hum at all without even the need of connecting the audio ground to chassis.
Old 20th May 2010, 11:14 AM   #7888
In that case, one may disconnect one RCA ground wire.
Old 20th May 2010, 11:23 AM   #7889
R.I.P.
Default disconnect 1 RCA ground
Which one and where?
I have never been able to eliminate hum coming from the ground loop created by a common ground in the source and the signal grounds of a stereo amplifier.
That's why I cop out and build monoblocks.
Help me.
regards Andrew T.
Old 20th May 2010, 11:31 AM   #7890
Unsolder the ground wire from one RCA input (into the amp)
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
