F5 power amplifier
F5 power amplifier
Old 9th May 2010, 02:42 PM   #7851
Marra is online now Marra  United Kingdom
F5 power amplifier
As a matter of interest were did UK builders get their heatsinks from?
Old 9th May 2010, 04:33 PM   #7852
dantwomey is offline dantwomey  Canada
Ah! the numerous will this heatsink work with my F5 questions........
It's my intention to build an enclosure that will start out with two of the heatsinks listed below and two F5 channels. From what I've read this heatsink should be quite capable of handling one F5 channel. So my question is. Will one of these heatsinks handle two F5 channels?
The enclosure I'm building will have enough room and power supply for four channels so the above question is key to my future plans.
Opinions anyone?
Dan
Old 9th May 2010, 06:28 PM   #7853
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
F5 power amplifier
Ehhh, no, I wouldnt count on that barely enough for one channel, but the 70mm long finning helps a lot
Personally I would use two each channel/mono blocks
sometimes we know very little, and sometimes we know too much
Old 9th May 2010, 06:42 PM   #7854
Yes. After searching through 'millions' of heatsink posts I found post #6969 where it said,
For F5 (standard build) the per channel consumption is about 80 watts and temp rise approx 25*C so heatsink thermal rate design is 25/80 *C/watt (= 0.31 *C/w) - plenty of examples of different proportions, widths, lengths, etc. Unfortunately, 2 seperate heatsinks will quite often track at different temps if not tied together via a solid plate for good thermal conduction and alter the behaviour of those carefully matched Fets.
So perhaps add one more inch to this heatsink to meet the recommended .31 *C/w.
Dan
Old 9th May 2010, 10:12 PM   #7855
F5 power amplifier
Hmm, its not ideal to use such "build up" method with this kind of cooling needed
Keep in mind that this is not a pepped up AB amp, but a real hot running design
With this kind of classA you need the most efficient cooling you can get
Too many "connections" means loss of expencive efficiency
You want to build a 4 channel amp, to save on cost, supply etc ?
I dont like the idea
You will need a HUGE supply to power that amp
Maybe its better to split them up in stereo amps
May even be less expencive, easier to build, and less messy inside
But why 4 channels ?
Also remember that 4 channels gets pretty hot in summertime
It could get unbareable to be in the room
And it could get really expencive with the power
This sounds like your first amp
Better keep it simple
Build a stereo amp, and see how it works
Who knows, maybe you will find another amp attracting next year..... M2 maybe, or BA-1 or 2
Below text is quoted directly from F5 Manual / FirstWatt (read the full manual, 10 times)
At 1.3 amps per channel, you will see idle heat dissipation of 62 watts. To keep the
temperature rise of the heat sink to 20 deg C. above the ambient temperature, you will want
a heat sink rated at about .6 deg C./watt for each transistor. An example of this would be a
chunk of finned aluminum, with a series of 2” fins attached to an 8” by 6” base. You will
need two per channel.
Old 10th May 2010, 06:17 PM   #7856
bear is offline bear
expert in tautology
bear's Avatar
F5 power amplifier
solid plate between is fine so long as both surfaces are FLAT and TRUE, and there is adequate "clamping" (screws) between the two surfaces. Keep in mind that screws deform the surfaces!
random aluminum heatsinks and random aluminum plates are not likely to make a good thermal connection. You'll need to make 'em flat... the more the total surface area between the two the less critical that becomes, but it is still not a factor to ignore.
Do not confuse the thermal mass of the backing place (the time it takes to get warm) with the transfer to the finned heatsink extrusion. They're different things.
But, I agree, if it's yr first build keep it simple to start, and make sure it works before getting exotic.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 11th May 2010, 02:56 AM   #7857
chchyong89 is offline chchyong89  Malaysia
Send a message via MSN to chchyong89
Dale RN50(1/10W) can work fine in the F5? seem like i can't even find out the quater watts RN50. It's for PD PCB.
Old 11th May 2010, 11:03 AM   #7858
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F5 power amplifier
Sure,
I think the 10R resistors might want to go to 1-2W.
I use them in PD boards just fine.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 11th May 2010, 12:31 PM   #7859
cjkpkg is offline cjkpkg  United States
I used THESE as PD mentions in one of his posts for all the small resistors. THESE are what I used for my source resistors.
Old 11th May 2010, 12:35 PM   #7860
vitalstates is offline vitalstates  United Kingdom
vitalstates's Avatar
this is a couple of years out of date but I think the references are still valid:
Vitalstates- Amplifiers
Ed
There is nowhere you can be that isn't where you're meant to be
www.vitalstates.org
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
