F5 power amplifier - Page 780 - diyAudio
Old 22nd April 2010, 11:47 AM   #7791
hesener is offline hesener  Germany
Hi chchyong89, is this a regular "electricians" screwdriver you are using (that is mainly used for testing line voltages)?
Old 22nd April 2010, 12:02 PM   #7792
awc is offline awc  New Zealand
When it sounds as good as this and other guys with high end gear agree, I dont care if all the component are inside out its sounds amazing.
Id like to make it dual 18v 300va I reckon it needs more VA.
how would I do that with out making it a dual Mono ?
join another 2 rectifiers + to +, - to -, another bank of Caps then ov to ov, would it Parallel lik that ?
That would give it 32 caps in total.
Old 22nd April 2010, 12:04 PM   #7793
Anyone ever tried F5 PCB from Jim's Audio (Hongkong)? Is it layot okay/correct?
Old 22nd April 2010, 12:13 PM   #7794
Talking Anyone ever tried F5 PCB from Jim's Audio (Hongkong)? Is it layot okay/correct?
Thats what mine is as you can always tell by the way the F5 is written on them, and once again they sound fantastic.
Old 22nd April 2010, 12:37 PM   #7795
Send a message via MSN to chchyong89
^i am curious about the connection of Q1 too
www.stoneracoustics.com
Old 23rd April 2010, 06:13 PM   #7796
Another question to ask...
Is it okay if the position of TH2 (4k7 Ohm) is reversed with R16 (2k2 Ohm)? Because they are in series connection, it would have the same final value right? Are there other specifics purpose on its placing?
Old 25th April 2010, 02:23 PM   #7797
jackies is offline jackies  United States
Also, in PSU, is there a point of putting a capacitor between + and -? Provided I already have enough capacitance?
Old 25th April 2010, 03:47 PM   #7798
acold7dusta's Avatar
like snubbers?
Squeezebox Touch>Coax>MH Dac 25.2>Marantz PM-15S1>Seas Thor (Small)/Beyerdynamic DT770
Old 25th April 2010, 04:31 PM   #7799
Of course I like snubbers!
I'm asking if there's any benefit from an additional (large) capacitor that is connected between positive and negative power rail, as opposed to existing capacitors that are rail-to-ground.
Old 25th April 2010, 06:25 PM   #7800
Hah!
After a thorough search found a dedicated thread:
comining rail to rail and rail to ground decoupling?
Apparently the conclusion was that it's pointless, at least from a theoretical standpoint.
But in this thread a person reports that he witnessed reduced sagging:
Filter Cap Directly from Rail to Rail, excluding Center Tap
Any other experiences?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright 1999-2017 diyAudio
