F5 power amplifier - Page 779 - diyAudio
Old 20th April 2010, 11:17 AM   #7781
Originally Posted by chchyong89 View Post
is 330watt enough for both channel?( although nelson recommend 200watt per channel)
330VA 18+18Vac has an AC current rating of 9.1Aac.
The maximum continuous DC current this transformer can supply is ~4.6A
if you draw 2.6Adc then it will be running at 57% of maximum continuous capacity. It should be OK, it may get a little warm, so keep it well ventilated.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th April 2010, 01:50 PM   #7782
udailey is offline udailey  United States
So, Andrew, where do you find these DC output transformers I bet they DO get warm!
Just joking. I know what you meant but had to take the rare opportunity.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 21st April 2010, 07:32 PM   #7783
Send a message via MSN to chchyong89
i tested with test pen on the signal in channel and the LED light up, is it normal and ready to connect my signal into it?
because i killed my preamp last time when i connect through the F5 board i solder last time. now i am scare to connect any signal into it again before any advance comments.
www.stoneracoustics.com
Old 21st April 2010, 07:41 PM   #7784
juma is online now juma  Germany
juma's Avatar
...i tested with test pen on the signal and the LED light up, is it ok to connect my signal into it? ...
Is that PCB that you are using for F5 bought on e-bay?
I saw one quite like it and it had errors. Check your PCB - compare it with schematic, it might be bad...
Old 21st April 2010, 07:42 PM   #7785
cviller is offline cviller  Canada
cviller's Avatar
Yeah, you should probably direct the questions to the one who sold you the boards.
Old 21st April 2010, 08:48 PM   #7786
awc is offline awc  New Zealand
Your green wire looks like it goes to + suppy ? dose your green come from ov ?
Old 22nd April 2010, 01:53 AM   #7787
"supply" sorry
these boards work fine, (sorry guys I got that board before I came across this site) Ive uploaded a pick of what to do.
DONT CONNECT SPEAKERS UNTILL voltage adjustments are set and then
use some old or cheap speaker make certain no noise coming through.
Old 22nd April 2010, 02:12 AM   #7788
I just re read your post. You need to check your soldering underneath as well with your light, you may have "sgn in" touching "-neg" power in.
Old 22nd April 2010, 02:34 AM   #7789
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Looks like the device legs below board could be touching active board lines they shouldnt touch
Because of too short device legs, bent too close to board
sometimes we know very little, and sometimes we know too much
Old 22nd April 2010, 10:16 AM   #7790
juma's Avatar
Originally Posted by awc View Post
...these boards work fine, ...
Please, check orientation of Q1 - it looks like it is turned the wrong way around.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
