F5 power amplifier
F5 power amplifier
Old 19th April 2010, 09:50 AM   #7771
R.I.P.
post7766.
are the two double insulated wires coming from the transformer, the mains input?
If yes, then they should be double insulated all the way back to the mains fuse and to the IEC input socket.
Twist all the wire pairs into and out of the transformer to minimise the radiated fields.
regards Andrew T.
Old 19th April 2010, 10:25 AM   #7772
chchyong89 is offline chchyong89  Malaysia
Send a message via MSN to chchyong89
here is my transformer lookalike
i am using two 330W E transformer, one for each + 24 and - 24 terminal. and after the crc is 25~26Vdc after measured.
u mean both the black "0" should go back to the earth?
Old 19th April 2010, 10:32 AM   #7773
R.I.P.
measure it with the bulb tester feeding the primary.
regards Andrew T.
Old 19th April 2010, 10:34 AM   #7774
Originally Posted by awc View Post
chchyong89;
On mine the F5 ground goes to speaker negative and input negative only, CRC ground goes to chassis earth, 18 0 to 1 rectifier and the other 18 0 to other rectifier with the 2 positive outs of rectifier joined together to CRC + and same with - from rectifier, hope that makes sense.
i am using the example shown by Click the image to open in full size.
i connect both 18Vac into one rectifier, which the 0 where to go is still a question
Old 19th April 2010, 11:30 AM   #7775
acold7dusta is offline acold7dusta  United States
acold7dusta's Avatar
on each rectifier you should have +18 and 0 going to both AC terminals
Bluesound Node 2>PS Audio Perfectwave DAC>Marantz PM-15S1>Seas Thor (Small)
Modified Squeezebox Touch>Millet Max>Grado SR60e
Old 19th April 2010, 02:26 PM   #7776
oh my god, i connecting both 18Vac into ac =_=
Old 19th April 2010, 03:00 PM   #7777
R.I.P.
do not connect any rectifiers to the untested transformer.
Just measure the AC voltage at the wire ends.
regards Andrew T.
Old 19th April 2010, 04:30 PM   #7778
can i ask more one question, actually is it 330watt enough for both channel?( although nelson recommend 200watt per channel)
i thinking to use only single transformer to power up this F5. i don't wish to waste my 4 pcs of same transformer.
Old 20th April 2010, 12:40 AM   #7779
alazira is offline alazira  United States
alazira's Avatar
The production F5 uses a 300VAC transformer, so your 330 will be fine. However, more is always better
Old 20th April 2010, 05:43 AM   #7780
HaflerFreak is offline HaflerFreak  United States
HaflerFreak's Avatar
Thought you guys might like a pic of one of my (nearly) finished channels. So simple, even a caveman could build it... No doubt!
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
