Old 17th May 2008, 12:01 AM   #761
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Default F5 parts from Digikey.
Miguel,
Here is a list of parts I have saved for F5 order from digi-key.
Not sure if this Thermisitor will work well, but here is the part #.
Other comments welcome.. Had trouble finding the Dale/Vishay 2.2k. Most of the other small resistor are dale 1/2 watt, cheaper than 1/4 watt. Easier to hold and see.
2
FQA19N20C (Min quantity is 250, not sure where to get smaller quantities)
MOSFET N-CH 200V 21.8A TO-3P
2
FQA12P20 (same as above)
MOSFET P-CH 200V 12.6A TO-3P
4
495-2161-ND
THERMISTOR NTC 4.7K OHM 5% RAD
8
P100W-3BK-ND
RES 100 OHM 3W 5% METAL OXIDE
4
3296W-502LF-ND
POT 5.0K OHM 3/8" SQ CERM SL MT
2
ZTX550-ND
TRANSISTOR PNP 45V 1000MA TO-92
2
ZTX450
TRANSISTOR NPN 45V 1000MA TO-92
4
P0.47W-3BK-ND
RES .47 OHM 3W 5% METAL FILM
6
CMF1.00KHFCT-ND
RES 1.00K OHM 1% 50PPM 1/2W
4
CMF10.0KHFCT-ND
RES 10.0K OHM 1% 50PPM 1/2W
4
CMF10.0HFCT-ND
RES 10.0 OHM 1% 50PPM 1/2W
4
CMF47.5HFCT-ND
RES 47.5 OHM 1% 50PPM 1/2W
13
4
CMF150QFCT-ND
RES 150 OHM 1% 50PPM 1/4W
8
P2.20KCACT-ND
RES METAL FILM 2.20K OHM 1/4W 1%
4
P6924-ND
CAPACITOR 33000UF 35V ELECT TSUP
8
P1.0W-3BK-ND
RES 1 OHM 3W 5% METAL FILM
2
GBPC2502A-ND
RECT BRIDGE 1-PH 200V 25A GBPC-A
4
BER178-ND
HEATPAD TO-247 .009" SP900
4
317-1214
CURRENT LIMITER INRUSH 10OHM 20%
Old 17th May 2008, 03:26 AM   #762
pencoat is offline pencoat  Canada
Mouser sold the FQA19N20C :
http://www.mouser.com/Search/Refine....=512-FQA19N20C
Old 17th May 2008, 03:56 AM   #763
Mouser's where I got the Fairchild parts I used in the GR-25. In general, if Digikey and Mouser both carry the same part, Mouser will be cheaper. Exceptions are rare. Mouser's service is every bit as good as Digikey. They're good people to deal with.
Grey
Old 17th May 2008, 05:19 AM   #764
sandstorm33's Avatar
Grey
Ordering online from Mouser on any size order is sent without additional cost .DigiKey charges $5 PLUS shipping for orders under $25. Bought the Fairchild mosfets for under $2 apiece . They shipped priority mail which reached AZ in three days. Shipping charge was $6.
See you later DigiKey!!!
Old 17th May 2008, 11:35 AM   #765
If you are ordering the fets from Mouser you also might check
out the aluminum oxide insulators much lower thermal resistance.
It is funny that they are listed in the heatsinks section.
Old 17th May 2008, 01:54 PM   #766
Skorpio is offline Skorpio  Denmark
Where can you find the JFETs?
I suppose the 2sk246/2sj103 have to low gm?
Old 17th May 2008, 02:10 PM   #767
You can have a look here :
http://www.ampslab.com/trans_2sj103.htm
http://www.bdent.com/search/part.jsp?partnum=2SK246BL
http://www.bdent.com/search/search.j...arch=Search%21
Old 17th May 2008, 03:01 PM   #768
jackinnj's Avatar
I have them on my webstore, but I am going to have to start limiting quantities.
NP says that the 20,000gm for the devices is necessary.
Old 17th May 2008, 04:29 PM   #769
The one and only
Nelson Pass's Avatar
Typical figure for these is about 8 ma per volt = 8 mS
The 2SK370 is about five times that, so that math doesn't quite
come out right. If you parallel the devices, the DC current through
them causes you to need a lower Drain resistance so as to set up
the right DC value to bias the outputs, and that lowers the effective
gain further.
They will work, just not as well.
I think a modification of the design would be required to use these
parts effectively.
Old 18th May 2008, 06:32 AM   #770
Mr. Pass,
Can you write a part list for F5.
Thank you
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.18313 seconds (66.78% PHP - 33.22% MySQL) with 11 queries
