F5 power amplifier - Page 769 - diyAudio
Old 5th April 2010, 11:23 PM   #7681
Renron is offline Renron  United States
Renron's Avatar
No aversion here, I prefer it! Aikido 6sn7.
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 5th April 2010, 11:24 PM   #7682
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by a.wayne View Post
What is the aversion to running a pre-amp with the F5 ?
I suppose none
Tho being a buffer, B1 is a preamp too, right
But if you have speakers with a bit "pronounced" top, you might be in luck that a passive attenuator rolls off the top a bit, if using longer interconnects
A tube pre with higher output impedance might do that too
sometimes we know very little, and sometimes we know too much
Old 6th April 2010, 12:16 AM   #7683
a.wayne is offline a.wayne  United States
Sin Bin
I have never heard a system that didn't benefit from a pre-amp , wouldn't leave home without one ...
Old 6th April 2010, 12:42 AM   #7684
labjr is offline labjr  United States
Some sources have have sufficient gain and output impedence built-in and don't need any additional preamp or buffer.
Old 6th April 2010, 12:52 AM   #7685
cviller is offline cviller  Canada
cviller's Avatar
But a preamp with gain will sound louder, which is appealing until you turn down to the level you had before...
Old 6th April 2010, 01:12 AM   #7686
Sin Bin
Christian,
When using your boards , shouldn't there be more gain than standard F5? There are a few questions on your F5 blog in need of some attn.......
regards,
Old 6th April 2010, 01:18 AM   #7687
acold7dusta's Avatar
Thanks to member Tea-bag, jazz, Cviller, A.wayne, Renron, and everyone that helped me along the way, I know have an operating amp! warming her up as we speak, and will fine tune in about 45 more minutes!
Thanks again guys- without your help I'd be going insane trying to figure it out. Don't get me wrong though-in the meantime I've learned so much more than if it would've went smoothly (take the good with the bad, ha)
Squeezebox Touch>Coax>MH Dac 25.2>Marantz PM-15S1>Seas Thor (Small)/Beyerdynamic DT770
Old 6th April 2010, 01:52 AM   #7688
cjkpkg is offline cjkpkg  United States
Update:
I FINISHED the F5...I am now running an Antek 600VA 18V toroid. The PSU caps are 4X33,000uF. Rail voltage is 23.9V on both sides.
I am running at 755mV for a bias of 1.61A - 800 was a little too warm. DC output is less than 10.
I am gaining much respect for the F5. At first I was disappointed with the gain but with the incremental improvements in the PSU and burn in time are turning this into a very respectable amp.
I broke down and ordered a B1 board and matched jfets from passdiy. It will be interesting to see how this combination works. I complain of gain issues but honestly I NEVER listen to music that loud.
Once I get the B1 built the next step may likely be some larger uber-efficient speakers for the living room. Unfortunately I am relegated to bookshelves. BIB's are not an option at this time.
Looking at the Fostex FE167s maybe...drivers need to be <$100.
Old 10th April 2010, 01:11 AM   #7689
getting some more time with the F5...been listening to XM jazz and XM chill line out to a homemade preamp - the UCP referenced in the chipamp forums. The speakers are diy Fonkens with fostex FE127E drivers eNabl'd(self).
I will post opinions when I complete the B1 build.
Old 10th April 2010, 01:18 AM   #7690
kp93300 is offline kp93300  Malaysia
Default DC offset of about 5 v !--help needed
I have been enjoying the F5 for the past 3 months.
Of late I notice that one channel has a high dc offset of 5 V and I am unable to trim it to below 4 V.
I can adjust the bias easily. I normally use .55V across the 0R 47 at R12 due to my small heatsink. .
After warming up for 45 minutes, I can adjust the dc offset to below 10 mv.
I have changed a new set of mosfet but problem persisted.
The other channel shared the same power supply and works well.
The thermister has been checked and Ok.
I need help to know where to troubleshoot.
thanks in advance .
kp93300
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
