Old 5th April 2010, 04:05 AM   #7671
tinitus is offline tinitus  Europe
It might work safer with device clips
Its tempting
I dont know if black anodizing are made in different ways
The only one I have tried to grind smooth with sandpaper showed a white and VERY tough layer of something between the black anodizing and the alu profile
Im sure that white layer isolates very effectively
Somehow I expect silver anodizing to be different
But the mounting screw may change things
Doing the needed thread can cause various things
Like material rise around the thread hole, etc
Old 5th April 2010, 05:50 AM   #7672
Renron is offline Renron  United States
Renron's Avatar
Pblossom,
Thank you for your input, yours is the only direct response from the "horses' mouth". They should know their products strengths and weaknesses.
Papa bought a case of Thermalcote for a reason.......Yes? Good enough for me!
Anodization is a great insulator, but fragile and prone to scratching.
I'll save the Arctic Silver for the CPUs, YMMV.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 5th April 2010, 06:01 AM   #7673
Renron's Avatar
A lifetime (and 1/2) supply on Fleabay.
One pound of Thermalcote. LOL
Ron
Old 5th April 2010, 07:15 PM   #7674
The one and only
Nelson Pass's Avatar
I did not say I bought it.
Old 5th April 2010, 07:30 PM   #7675
Hello Mr Pass,
I'm building an F5 amp, to feed a pair of 94db/2,83v speakers, do you think I'll need a preamp to get a realistic level ?
Thanks for sharing - this is my first pass diy project !
Old 5th April 2010, 07:42 PM   #7676
The gain of the F5 is ~6times (~+15dB)
the max signal from a cdp is ~2.1Vac.
The max signal from the F5 will be ~12.6Vac
This is equivalent to ~20W into 8ohms. Not quite full power.
The F5 sensitivity is just slightly more than most CDP and considerably more than lower voltage sources. A pre-amp with gain may be required depending on the voltage from your sources.
Now let's look at what SPL you can get.
20W is 13dBW.
The speakers are 94dB/W@1m.
The maximum SPL is ~107dB @1m
If your average level is 20dB below your maximum then your average listening level with zero attenuation from a 210mVac signal (-20dB ref 2.1Vac) will be ~87dB @ 1m. That is getting pretty loud for most listeners. But that requires a high maximum voltage source. Maximum average level will depend on your source voltage.
regards Andrew T.
Old 5th April 2010, 08:31 PM   #7677
So,
for my domestic purpose, I guess It will be sufficent, with cdp or phono preamp, isnt'it ?
Old 5th April 2010, 08:37 PM   #7678
Bigun is offline Bigun  Canada
Bigun's Avatar
Seems to me you don't need a preamp. But look on the bright side, if you find you need a little more gain you have a reason to build a nice preamp
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 5th April 2010, 08:41 PM   #7679
Renron's Avatar
Thanks for makin' us laugh Papa.
BTW, Love my F5!
Ron
Old 5th April 2010, 11:07 PM   #7680
a.wayne is offline a.wayne  United States
a.wayne's Avatar
What is the aversion to running a pre-amp with the F5 ? it seems that the gain is of some concern, No ? ...
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.18576 seconds (65.56% PHP - 34.44% MySQL) with 11 queries
