Old 31st March 2010, 05:23 PM   #7601
bobodioulasso's Avatar
Am i mad to use expensive screw terminal caps 7mohms ESR?
Old 31st March 2010, 05:54 PM   #7602
HIPCHECK's Avatar
If any body is in need of caps I have several new in box Illinois Capacitor 25V 15,000UF caps. pn# 159LBA025M2ED. I would be glad to sell some for cheap I have a lifetime supply of them. I figured I could build almost all pass amps I wanted to with them (Mini A, AlephX, F2, SOZ, etc).
I really need about 8 IRFP9240 Mosfets. I would be happy to trade some caps if you have spares.
Heres the Link, pdf was just a little too big to attach
159LBA025M2ED datasheet pdf datenblatt - Illinois Capacitor, Inc. - 85¡ÆC Snap-Mount Aluminum Electrolytic Capacitors ::: ALLDATASHEET :::
If a inch of duct tape will fix it, 3 feet should fix it for life!!!!
Old 31st March 2010, 06:19 PM   #7603
pixeljedi's Avatar
Originally Posted by Renron View Post
With that much capacitance don't forget the soft-start thermistors, or you'll own stock in a fuse company.
Ron
Thanks Ron, I'll definitely add in the soft-starts. I'm only going to go with 8, just picked up 2 extra.
Does anyone have experience running the TSUP line of caps in an F5? Would they be ok to use, or should I seriously consider using something else?
Thanks,
Thor
Old 31st March 2010, 08:42 PM   #7604
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
they're certainly more than good enough
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 31st March 2010, 09:10 PM   #7605
cjkpkg is offline cjkpkg  United States
Originally Posted by cjkpkg View Post
Well if I redo the PSU, do I get another set of psu boards and another 300VA xformer or just replace the existing with a 600VA unit?
It would be easy to add another 22,000 uF per rail.
OK, I decided to go the 600VA xformer route and up the caps to 33,000 uF - 132,000 total uF.
Dont get me wrong - I am not disappointed in the sound of the F5 - I was just expecting more umph out of it. Serves me right for skimping on the PSU...
I wonder how the Aleph mini would sound with 4 more 22,000 uF caps and the 18V xformer?
Old 31st March 2010, 09:14 PM   #7606
nigelwright7557's Avatar
I found I couldnt get a decent transient sound with less than 40 volts DC.
All my amps run off +/-60 volts DC so the transients arent clipped.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 31st March 2010, 09:31 PM   #7607
Zen Mod's Avatar
maybe your speakers are "issue" - not amps ;
I can't find any lack in transients with Papamps in range of 30W/ch , at least when using speakers intended for that , even of 16ohms variety .
in any case - you found working solution , for your circumstances .
Old 31st March 2010, 09:38 PM   #7608
The speakers werent the problem, they were good quality and high effiecncy speakers.
When I looked on the scope the transients were clipping even for moderately loud music at 40VDC.
Old 31st March 2010, 09:46 PM   #7609
tinitus is online now tinitus  Europe
Definately not "party amps"
But amps are not to blame for that
And you may get something else instead
Things you usually wont get with big power amp
Thats the whole point from the beginning with FirstWatt
Theres still not "one size fits all"
You need to know what you want, and learn how to achieve it
That matters more that anything
The best isnt the best, if it doesnt do what you want
But true, the best amp amps will be of little help if your speakers doesnt match
Old 31st March 2010, 10:57 PM   #7610
The one and only
Nelson Pass's Avatar
I play Barry White at my parties, where a couple watts are plenty.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
