| Thread Tools | Search this Thread |
#751 |
Jack, I was specifically looking for the radial power resistors, but thanks for the extra info! It looks like DK has some alternate parts, so I am pretty sure things will be good.
#752 | |
Official Court Jester
look HERE and few posts down more than 2 yrs ago ; made by my friend Oly , as result of mine hysteric Babelfish J conundrum ; as you can see - with all differences , most important one (of many) certainly is difference in feedback arrangement , which is in F5 natural implementation of feedback from toob world I'm pretty sure that F5 sounds pretty simillar to little Oly's symmetric amp , or vice versa . so - my conclusion is - it sings pretty much in same league as Babelfish J ( or Aleph J ,whatever ) with minor difference - it's more capable to drive more demanding spks ; you can place here usual mumbling about preferences/taste for odd vs. even harmonics in THD spectra ..... one more time - you can see what Papa's lateral thinking is ; ordinary amp designer always look and chase equal impedances on both sides of diff stage ; Papa just neglected diff stage ( or LTP , in any of incarnations ) , making space for something not new , but certainly not seen so lately . I can write more , but I'm lazy ....... don't count on my awareness what I'm actually writing ![]() edit: Papa- this time you spoiled my answer ....... while I'm typing .....
my Papa is smarter than your Nelson ! tnx to |
#753 | |
Ot you just |
#754 | |
![]() amp was build in form of prototype , meaning that pcb are made, populated ,connected to PSU and all settings were done . I listened to it several hours .
#755 | |
Zen Mod, can you please post PCB file for symmetric amp. Thanks in advance
#756 | |
unfortunately - I don't have it ..... but - it's easy for any sort of PtP
#757 | |
Who is "Oly". Maybe |
#758 | |
The one and only
disappointed, but I can attribute that mostly to IR P channels operated Common Source. Other P channel parts will work better for this. Still, I don't expect that it will sound that similar - the diff pairs on the input do have a different character to them. Relying on (bad) memory, I think that the F5 has a more extended top end. |
#759 | ||
![]() yeah,Papa , I learned that lesson form you ; in fact - used parts were IR IRFP140 and Fairchild IRFP9240 ( sorta better complement ? ) Quote:
clever feedback arrangement...... I remember - when I was a kidoe - making my first OP based preamp ; first one was anemic ; just later - when I change (maybe even just by mistake , not because of any lucida intervala ) feedback net to low impedance one , funny little OP based thingie almost started to sing ... maybe these audio electrons just prefers easiest paths ![]() so - my conclusion is that - even if I didn't make your (our?) newest toy , I think that I have slight idea how it sounds .... better than little Oly's amp , but similar in character . regarding Oly's , Plantefeve's and similar amps ...... for me - electronics is somewhat as Jazz - take already well known tune (standard) , make it by your way - you have your tune ; better or worse that other interpretations - another issue , but certainly your ![]() F5 is jewel ; not exactly break-trough as Alephs and SUSY , but certainly example of cunningness ......... is it really easiest to see Buda in details ?
#760 |
I am gathering parts for the F5 from Digikey and two issues come up:
1. Digikey carries Dale RN resistors, but at 0.1 and 0.05 W. So, it is better to use these or to use the ones from Yageo? 2. What part number should I use for the thermistors? Sorry for the questions, but this is not my expertise after all ![]() I remember when I made a Zen V4, parts list included in the article |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| Oreda, ce |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.17666 seconds (57.43% PHP - 42.57% MySQL) with 11 queries |
