F5 power amplifier
F5 power amplifier
Old 31st March 2010, 02:15 AM   #7581
cjkpkg is offline cjkpkg  United States
Well if I redo the PSU, do I get another set of psu boards and another 300VA xformer or just replace the existing with a 600VA unit?
It would be easy to add another 22,000 uF per rail.
Old 31st March 2010, 02:22 AM   #7582
dantwomey is offline dantwomey  Canada
Recommended 300VA per channel?
Dan
Old 31st March 2010, 02:28 AM   #7583
labjr is offline labjr  United States
I don't think it matters much if you do mono or stereo. Try adding the capacitors first. I just wonder if the 300VA Antek is enough transformer. Most have built the F5 with a 400VA Antek. Won't hurt to have a little extra.
Old 31st March 2010, 02:33 AM   #7584
danieljw is offline danieljw  Australia
danieljw's Avatar
Send a message via MSN to danieljw
Having built one myself i have a much heavier duty power supply.
however i think the issue may be gain i find mine sounds better with a preamp of some sort in front of it.
depending on the output of your source unit.
i am listening to mine everyday at the moment
-Dan
Old 31st March 2010, 02:42 AM   #7585
Bigun is offline Bigun  Canada
Bigun's Avatar
F5 power amplifier
Dan,
How would you compare the sound of your F5 with your Le Monstre - the F5 looks like it came from the same DNA ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 31st March 2010, 03:49 AM   #7586
danieljw's Avatar
Hi Bigun,
The F5 has less gain, has a very low noise floor (supply/build/case affects this)
And a very natural sound. i think the F5 sounds a little more laid back than the monstre but is not dissimilar.
both are really nice
-Dan
Old 31st March 2010, 03:54 AM   #7587
danieljw's Avatar
Also you are right about the DNA - i used the same case with modded supply for the F5
however i opted for a regulated supply with alot of capacitance
-Dan
Old 31st March 2010, 06:50 AM   #7588
pixeljedi is offline pixeljedi  United States
pixeljedi's Avatar
Originally Posted by Tea-Bag View Post
Dan,
I would personally go for the 470000uf panasonic one's on Ebay.
2pcs Panasonic Radial Capacitors 47000uf 25v 85C - eBay (item 200449742234 end time Apr-12-10 09:54:46 PDT)
I've bought other stuff from this guy before. Quick service.
I use 4x 47000uf Panasonic's in my F5. Under load, the are 22.5v on V+, at least on mine.
Thanks for the link! Just ordered 10
Old 31st March 2010, 03:28 PM   #7589
Renron is offline Renron  United States
Renron's Avatar
With that much capacitance don't forget the soft-start thermistors, or you'll own stock in a fuse company.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 31st March 2010, 03:40 PM   #7590
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
These are "general purpose" quality.
An F5 deserves better than this. Something like high ripple, low ESR.
Quantity does not replace quality .
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
