F5 power amplifier - Page 757 - diyAudio
Old 28th March 2010, 01:26 AM   #7561
acold7dusta's Avatar
are the shorted input necessary for testing? i didn't see it anywhere in the guides, so i didn't do it.
Squeezebox Touch>Coax>MH Dac 25.2>Marantz PM-15S1>Seas Thor (Small)/Beyerdynamic DT770
Old 28th March 2010, 01:29 AM   #7562
nigelwright7557's Avatar
If the input is floating it might pick up mains hum and rf which might confuse readings.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 28th March 2010, 02:10 AM   #7563
it won't cause damage without it though, correct?
Old 28th March 2010, 03:15 AM   #7564
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
True.
Old 28th March 2010, 06:11 PM   #7565
expert in tautology
bear's Avatar
pots read 0.3R, the fuse is fine, and my 0.47R resistor reads 0.5R. not sure why my other resistors are all now out of wack though...
Most, not all, DVMs have a small offset at very low resistance ranges... check to see if you get 0.00 with the leads connected or not.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 28th March 2010, 07:48 PM   #7566
_-_-bear
I get 0.2 ohms when they're connected directly. The 0.47R reads 0.7ohms uncorrected, and the pots read 0.3, which is 0.1 corrected
Old 28th March 2010, 08:51 PM   #7567
here are my resistor values that are out of wack. This is for the left channel, and the right channel is similar (as well as my other boards)
R1&R2: 8.1R, 8.5R (10R)
R5-R8: 12.3R, 15.8, 7.2, 15.8 (100R)
R15&R16: 1.6K (2.2K SERIES 4.7K)
R17&18: 130R (1K)
R19&R20: 130R (150R, NOT TOO BAD)
R21&R22: 130R, 173R (22K!)
does anyone know what is going on with my amp? my other boards read the same numbers and that's why i bought new parts and boards because they read so much off.
The resistors were all normal before they were loaded (didnt check after they were mounted though)
readings were as the amp hooked up to the PSU, but not 120V wall power
Old 28th March 2010, 08:55 PM   #7568
udailey is offline udailey  United States
You cant measure the value of a resistor once you put it in the board. It ends up being in series and parallel with other resistors. Maybe you put in a 1k resistor that goes to ground and elsewhere you put in another resistor of 100R that goes to ground and if you measure from both sides of the 1k you measure the value of a 100R in parallel with a 1k. That would be kind of simple but then you resistors in series somewhere between those two and others going to ground and it ends up a mess to measure while in circuit.
Like look at your R21 and R22. They must be parallel to a resistor that is close to 150R. Probably R19 and R20 but I am not looking at the schematic right now.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 28th March 2010, 09:05 PM   #7569
well that clears that confusion up thanks
Old 30th March 2010, 01:47 PM   #7570
I was looking around for caps for my F5 and came across this deal on FleaBay 200pcs 15000uf/25V Capacitor.
At about 63 cents a piece before shipping they're not a bad deal for those on a tight budget.
Dan
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
