F5 power amplifier - Page 753 - diyAudio
Old 24th March 2010, 05:29 PM   #7521
EUVL is offline EUVL  Europe
Not always.
And it also depends on how you define close.
Patrick
Old 25th March 2010, 01:11 PM   #7522
Originally Posted by bobodioulasso View Post
Massimo,
it looks like a bad solder joint.
It seems you were right, the soldering appeared all good but...
Last time I checked, I got V+ on P-ch mosfet source with pots at zero. Bending lightly the board I got zero or V+ as an intermittent contact was in action.
I've decided to populate a new board (I took a couple for spare and was a good choice at this point) so I desoldered all the components from the "faulty" one. The mosfets seem to work correctly at least with the test alazira mentioned earlier (same procedure can be found at Basic Testing of Semiconductor Devices).
The bare "faulty" board shows a very difficult continuity between both mosfet source and their relative resistor (R11/R12). Could it be the problem?
The other twin mono still works perfectly stable.
Originally Posted by bear View Post
...............................This is assuming that something else isn't a wrong value or miswired or otherwise malfunctioning...
Your final words were profetic
Old 25th March 2010, 09:03 PM   #7523
I'm thinking about building two F5's, a total of four channels, to bi-amp my speakers. How I'd like to biamp them is just tie the two inputs of each amplifier together with a single RCA connector. This would mean that I would only have a single interconnect going to each amp but dual speaker cables going to the bass/treble connectors of my two-way speakers. Referring to the original schematic in post #89 I'm wondering if I'd have to change the values of R9 or R10 to prevent my preamp from seeing half the input impedance it normally would on a power amp. Suggestions anyone?
Dan
Old 25th March 2010, 09:07 PM   #7524
nigelwright7557's Avatar
Usually a pre amp out is much lower impedance than the input of a power amp.
My preamp is about 100ohms output impedance and the power amp is 47K input impedance so nothing to worry about there.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 25th March 2010, 10:19 PM   #7525
bobodioulasso's Avatar
Originally Posted by dantwomey View Post
I'm thinking about building two F5's, a total of four channels, to bi-amp my speakers...
Dan
Don't you think a filter between preamp and amps would be a better way?
Old 25th March 2010, 10:28 PM   #7526
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Fore biamp I would consider a preamp with double preamp modules
The one for woofer amp would have more gain, and additional attenuator
Or just additional preamp module for woofer amp
There are a few with adjustable gain
sometimes we know very little, and sometimes we know too much
Old 25th March 2010, 11:36 PM   #7527
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
one could tweak the gain at the amp level by adjusting R6 and R7 a bit. probably better to do so on a bass amp side as to not muck up house F5 clone sound.
Salas Boards GB 2017#1 ON ORDER | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards On ORDER
Old 26th March 2010, 12:13 AM   #7528
If 'Father Pass' and others give my idea a thumbs down then I'll probably go the traditional route with monoblocks.
Dan
Old 26th March 2010, 12:51 AM   #7529
Biamping a passive speaker doesnt automatically lead to better sound
I have had no luck with that
Others will say they have
My guess is that it very much depends on the actual speaker, and how its done
But it could be a step on the way to making an active speaker with DSP
But again, I might consider combining F5 with a different kind of amp for the lows
I think a pair of F5 monos would be a good choise fore further devellopments
If you insist on two F5 stereo amps, I would suggest one as pr original F5 with single pair output devices
And the other with double pairs
Old 26th March 2010, 01:16 AM   #7530
expert in tautology
bear's Avatar
F5 is 10dB lower gain than a typical power amp - I'd put the attenuator on the woofer side, unless you have 10dB more efficient (sensitive) tweeters... do the math first...
I'd buffer a second output for the woofer, but all buffers do not sound the same... I've yet to find a transparent DSP, but it would be nice...
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
