F5 power amplifier
F5 power amplifier
Old 22nd March 2010, 09:31 AM   #7491
sekess is offline sekess  United States
Originally Posted by jacco vermeulen View Post
Good for you, i certainly did not.
Hey Jacco,
When I said I got it now, I meant Andrew's post. I was in a hurry and did not have time to elaborate.
For some reason, initially, only the top portion of his post came through. I uderstood what he said. But, I did not understand how the current draw is different between the balanced and bridged versions (for the same impedance loads).
Thanks,
Steve
Old 22nd March 2010, 12:46 PM   #7492
bear is offline bear
expert in tautology
bear's Avatar
F5 power amplifier
Originally Posted by EUVL View Post
Are they matched at room temperature or at steady state on heat sink ?
Curve tracer matched Quad Comps are a must for those serious builders for Xed F5.
Can your curve tracer output data in digital format for post processing ?
Patrick
Room temp, which is cool.
The device does not heat much during test, unlike a static bias test jig.
I could let them cook for a while (actually I did... on a few to look at the change) but my experience with the Hitachi's is that there isn't a whole lot of difference in the spread when tested warm or cool. The pix from Luvdunhil's posts when he was selling them shows the same thing... fwiw. No worries, mate! ;D
this is an older Tek 575, no digital anything. Toobes to test tranzeesterz!!
Yes, for the X5 or the CViller boards having the devices on each rail very close is important...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 22nd March 2010, 07:32 PM   #7493
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
F5 power amplifier
I was told that theres no matching of NPN to PNP
Matched pairs are 2x matched NPN, and 2x matched PNP
So, fore F5 with single pairs theres no need fore matching
sometimes we know very little, and sometimes we know too much
Old 22nd March 2010, 09:15 PM   #7494
hags is offline hags  United States
Correct.
"Some lures are designed to catch fish, others are designed to catch fisherman."
Old 22nd March 2010, 09:46 PM   #7495
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by bear View Post
I only have a few sets for sale in the swap area...
First come first served.
If the demand is huge, I can go and buy a really large batch...
Post there, not here.
there is here:
TOSHIBA MOSFETS
Awayne, out of this batch there was no possibility to find the number that you wanted. Zilch. I would need a batch of 200-400 per type to find the number you wanted...
So, post up if you want them, even if I run out (and I will, there aren't that many to begin with...) otherwise I won't want to go out and buy several hundreds of each type myself.
_-_-bear
Yes i need as we previously discussed , so go ahead and let me know ....
Old 22nd March 2010, 10:00 PM   #7496
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
So, for F5 with single pairs there's no need for matching
This is true. However, if you know what you are looking
for, there's nothing that beats socketing parts and swapping
them in and out until you get what you want.
Currently I do this with J2's, as I have not found a matching
pattern that easily predicts performance. Of course this also
has to be done at temperature.
Old 22nd March 2010, 11:12 PM   #7497
Default Sockets
That's an excellent idea -- does anyone have a part number for TO-247 device or similar?
Thanks,
Steve
Old 23rd March 2010, 12:48 AM   #7498
expert in tautology
bear's Avatar
F5 power amplifier
I wouldn't say that exactly.
I'd bet with a big lot of P & Nch maybe 1000pcs of each there would be a few dozen or so that would end up being dead on or nearly so in the center of the "sweet zone" - that being the overlap of the bias points...
Not having had enough in my hands of the Tosh's I can't say for sure how they usually end up. The old Hitachi metal can J49 & J56 (iirc) and their complements were overlapping to a small degree... I was able to find some that were dead bang on, but they did not have (allegedly) matching transfer curves as do the Tosh's...
_-_-bear
_-_-bear
Old 23rd March 2010, 01:13 AM   #7499
F5 power amplifier
Ok, I just wondered about your batch #3#
Just one single set of matched pairs
One channel bought as a stereo set
Matching makes the 2 pairs cost more than common commercial unmatched devices
Maybe a mistake, but it seems pointless
In fore a refund ?
If you had split your matching up in ALL martched pairs, instead of matched quads, you might have gotten more and better matches, and cheaper
Old 23rd March 2010, 02:12 AM   #7500
expert in tautology
bear's Avatar
F5 power amplifier
It doesn't work that way tinitus...
The way I did it was to characterize all the devices without regard to where it was going to go. Then I looked at them. My interest was to get good matches for my own Cviller boards, even if I build them up as std F5, at least to have enough devices.
So after looking at the groups it became immediately obvious that there were a number of very lucky "quads" in both N & P. Knowing that some people want to make Cviller boards I offered them up as N + P quads.
The advantage of quads is that the bias points on both channels of the F5cv will bias at exactly the same point. Since NP has stated that the bias point effects the harmonics and the way the amp sounds, this way one is assured of having two channels that are indeed so similar as to be deemed identical in this regard.
If you build without each gender of device being the same Vgs between two channels, maybe not such a big deal, maybe is... but in the F5cv build it becomes important because the devices are running in parallel.
All in all it is merely closer to some degree of "perfection".
Not necessary at all to make the amp run, but also not a bad idea if you are trying to optimize.
And, yes, matching costs more than unmatched common commercial devices... there is time and effort involved, plus the outlay of cash to acquire a sufficient number of devices to arrive at a match...
I guess it all depends on what you think is important or what you want...
No one is obligated to buy anything?
_-_-bear
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
