F5 power amplifier - Page 741 - diyAudio
Old 16th March 2010, 06:35 PM   #7401
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by hags View Post
I've always had good luck with sil-pads, good heat transfer, easy to use and inexpensive. No complaints here.
I replaced the rectifier bridge in my Acurus A200 with an RFB02 board with discrete components. I used MUR6030s with 2 ohm resistors and 100nf caps.
The difference in sound was noticable and immediate.
Was that due to the snubbers? I don't know.
I have used the same recifier boards with my F5 build. I couldn't be happier with the subjective performance.
I was looking at using Mur3020 ....................
Old 16th March 2010, 06:43 PM   #7402
hags is offline hags  United States
I bought a bunch of MUR6030s for the quantity discount. I'm able to use them in a variety of applications without worrying about the voltage rating.
I see no downside to the higher voltage/current rated device except maybe voltage drop, for which I haven't noticed a difference.
"Some lures are designed to catch fish, others are designed to catch fisherman."
Old 16th March 2010, 06:54 PM   #7403
Sin Bin
what about Shcottkey diodes ?
Old 16th March 2010, 08:00 PM   #7404
Renron is offline Renron  United States
Renron's Avatar
68nF snubbers with MUR860 diodes for the bridge
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 16th March 2010, 08:01 PM   #7405
Sin Bin
Are you guys calculating the snubber values ?
Old 16th March 2010, 08:16 PM   #7406
alazira is offline alazira  United States
alazira's Avatar
Originally Posted by prooptiki View Post
I want to share some more impressions for the f5.
As I said I use large skins, so after many hours the temperature stays to about 40oC, so after reading I started playing with the bias...
0.60v >>> 40oC >>> 65oC (mosfet)
0.71v >>> 43oC >>> 80oC (mosfet after 30min)
Seems like Hags and I are in the minority with the sil-pad. My result when increasing the bias:
1.5v/.91=1.65A : 65C heatsink : 75C mosfet @1hr
In theory the sil-pad should be more effective than mica/goo or Al-Oxide pads/goo, but your actual mileage may vary.
Old 16th March 2010, 08:36 PM   #7407
I don't know about theory but I can tell you I got a little more heat transfer using the sil-pads than the alu-oxide with grease.
Like I said, if I had the sil-pads on hand at the time I would've used them. I didn't so I went with the alu-oxide.
Both work well IMO, I think the sil-pads work slightly better and I like to work with them more so than the grease.
Old 16th March 2010, 08:37 PM   #7408
Renron's Avatar
Long ago in this HUGE thread, Nelson Pass stated that he uses Ultra fast diodes and prefers Mica for insulators.
NO, I don't remember which post #. LOL
Ron
Old 16th March 2010, 08:41 PM   #7409
cviller is offline cviller  Canada
cviller's Avatar
There is a "mica and goo" thread somewhere here on the pass labs forum by papa, where he sums up his findings. AFAIK the result was that sil-pads were fine if the surface was flat, but mica and goo was better if there was surface was not perfect.
Old 16th March 2010, 09:11 PM   #7410
alazira's Avatar
I remember NP's recommendation so I tried it, but instead of silicone goo I used artic silver. The heatsinks ran at 40-45C and didn't think about it for several weeks before checking the mosfet temps and they ranged from 100C to 120C! After removing them I could see that the artic silver did not spread evenly despite my best efforts. That's what I get for trying to be fancy and not using the regular grease which spreads better.
Bottom line is that contact area is perhaps more critical than thermal conductivity or thinness.
The sil-pads need to be torqued down to make sure there are no air pockets, so in this sense they are less forgiving than grease.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
