| Thread Tools | Search this Thread |
#731 |
My personal experience with this has been via Jeff Rowland, Aesthetix, Sonic Frontiers gear...and of course Pass Labs. I can remember Cardas and Neutrik in a few cases....but I think Jim White at Aesthetix was using something else.
Chris |
#732 | |
The one and only
#733 | |
not politcally affiliated
Is there a problem just running standard XLR's here, with some 18GA cable? Will too much current melt the connectors plastic? ![]() My battery powered tube preamp is using them with Cat5 cable without any issue. ( I know of) Mike |
#734 |
diyAudio Editor
Speakon's have up to 8 contacts, and are made for higher amperage-30A continuous according to the spec sheet. . Also are non-shorting...
They are my plan- unless I have a row of speaker type terminals.... and spade connectors on the wires. http://www.partsexpress.com/pe/showd...number=092-050 http://www.partsexpress.com/pe/showd...number=092-051 http://www.partsexpress.com/pe/showd...number=092-052 http://www.partsexpress.com/pe/showd...number=092-053 http://www.partsexpress.com/pe/showd...number=092-054 http://www.partsexpress.com/tech/092-051.html etc |
#735 | |
#736 |
For that kind of connections i've been using Hirschmann Stas/Stak for decades, assembled a 3-piece Gerard Perrot (Mr Lavardin) amplifier design that was published in l'audiophile with them.
The Stas/Stak connector system is also highly water resistant, from 2 to 5 pole versions, example A picture of the 2-pin types =>
Looks like Sponge Bob has killed another thread. |
#737 | |
Formerly "jh6you". R.I.P.
I read a book: Whenever the feedback voltage is proportional to output current, the circuit has current feedback. Current feed back stabilizes the output current. This means that a constant input voltage produces an almost constant output current, despite changes in open-loop gain and load resistance. For instance, suppose the open-loop voltage gain decreases. Then the output current tries to decrease. This results in less feedback voltage and more error voltage. In turn, this means more output voltage and current. The increased error voltage almost completely offsets the decrease in open-loop voltage gain, so that the output current remains almost constant. A similar argument applies to an increase in open-loop gain. Attempted increases in output current are almost eliminated by the negative feedback. Noninverting Current Feedback: Transconductance -- Decreases Input impedance -- Increases Output impedance -- Increases Distortion -- Decreases Output offset -- Decreases Inverting Current Feedback: Current gain -- Stabilizes Input impedance -- Decreases Output impedance -- Increases Distortion -- Decreases Output offset -- Decreases For this, the load resitor (speaker) and feedback resistor are in series, as I understand... Hope I did no mistyping... |
#738 | |
#739 |
The one and only
I think you have the wrong idea here. The F5 uses what I would
refer to as low impedance voltage feedback - as pointed out earlier the circuit is a CFP "complementary feedback pair" variant. Maybe it should be called a complementary-complementary-feedback- pair-with-voltage-gain. CCFPWVG is a snappy acronym, no? The point of my comment in the article is that this is routinely referred to as "current feedback" in the op amp literature, but it has been mis-named in this regard. |
#740 | |
So in theory XLR's or "microphone" jacks can be okay (I use one per channel). I have not tried it with 1stWatt amps yet, but plan on doing so as well. I have plenty of XLR's right now, no power or speakerconns. |
| Currently Active Users Viewing This Thread: 4 (2 members and 2 guests) | |
| Dennis Hui, Bksabath |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.20806 seconds (59.73% PHP - 40.27% MySQL) with 11 queries |
