#7311 |
Hello Oscar ,
Were you able to get any bench testing done ? regards. |
#7312 |
Hi a.wayne,
I did the conclusions based on sounding performance of my F5. I have no signs of audiophile (im use only standard parts - 1% Metal film 0.6W all small resistors and power film 3w resistors and vishay transistors). but the measurements of the my F5 amplifier is well (square wave response, bandwidth etc..),also design is on top (thank you Mr.Pass for sharing it). So it is not sounding bad-its sound so great IMHO. Now I thinking of another DIY Pass amp construction for my brother - maybe Aleph J or F4. regrads, oskars
If time is money then I'm out of time |
#7313 |
Try an F3 for something really quite different!
... jh |
#7314 |
thanks for the advice
now will read an article about f3, sorry for OT.
#7315 |
expert in tautology
prooptiki, I can't tell from the pix which way is up. But if the transformer is down, you might consider putting the F5 board and output devices closer to the bottom of the heatsink.
It may not matter because you have a very large heatsink - but see how hot it gets after about 6 hours of being on, after the heatsink reaches some sort of thermal equilibrium. Wondering if you milled the backside of those heatsinks or if they came that way? _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#7316 | |
I made some changes to the thermistors, now they are on the mosfets! But still the heatsinks are too big, for about 36hours on power, the amplifier is colder than my cd player!!! I am going to try covering the heatsinks... The heatsinks came as the are now, 40euros!! Last edited by prooptiki; 12th March 2010 at 04:33 PM. |
#7317 |
40 euros? from where? i have search anywhere but the prices are..................very high
#7318 | |
just a thought, but if it plays too loud you could increase R9 or even better reduce R10 (100K trimpot would be good here)
#7319 |
Hi - I have a pair of F5s built using Peter Daniels board - apart from the excellent sound I am getting a rather odd effect. If I touch (or just move my hand near) the heatsinks then the volume drops to nothing for about half a second and the fades back in rapidly.
Weird. ![]() Even weirder is that once I have done this and then touch the amp again there is no effect. |
#7320 |
Banned
Have you conected your chassis to earth?
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
