F5 power amplifier
F5 power amplifier
Old 8th March 2010, 08:10 PM   #7281
kalinowski is offline kalinowski  France
Hello,
sorry if it has been covered before but I've read about half of this thread and this took me two weeks worth of my spare time
I wonder if any of the semiconductors in standard F5 have to be matched? I think there's no need to match output devices cause I can adjust their bias with P1-P2.
How about input jfets?
Can I substitute transistors from protection circuit(Q5-Q6) with something more available like BC550-560? If not what makes zetex devices so special for our application?
looking forward for your help/explanation,
thanks
Michał
Old 8th March 2010, 08:29 PM   #7282
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
F5 power amplifier
BC...
Yes, but reversed
Cvillers guide would be good to read
http://viller.eu/audio/2009jan_gbf5/gbf5_guide.pdf
Yes, I think its best to use mayched Jfets, to make easier dc adjustment
sometimes we know very little, and sometimes we know too much
Old 8th March 2010, 08:34 PM   #7283
cviller is offline cviller  Canada
cviller's Avatar
You don't need to match the jfets, but I seem to remember to have read somewhere that jackinnj made some tests where he got better thd with matched jfets.
Old 8th March 2010, 08:43 PM   #7284
Thank you for your fast replies. I think I'm gonna make first version with cheapo components and then, if I like the overal sound put some more money into fancier, matched devices/resistors.
One more thing: In your guide, Cviller, there's written in the PSU section:
"1-2 thermistors for soft starting the toroid"
If I'm not plannig to use any thermistors at all should I use slo-blo fuse or just bigger one?
Old 8th March 2010, 08:48 PM   #7285
cviller's Avatar
It depends on the toroid you use. Way back, I tried without soft start thermistors running at 230V and the 4A slow blow fuses literally exploded.
Old 9th March 2010, 03:03 AM   #7286
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
I think the results were only a gnat's hair better -- and there was certainly no rigorous scientific method involved. You can use a BL as one JFET and a GR on the other and the amplifier will still work.
The Zetex's can be substituted, but be mindful of orientation (which Cviller has attended to.)
The output devices are of their own mind and don't have to be matched.
If you're building the amp just to measure THD% the 10K/22K resistors on the limiter can be swapped around, the source resistors on the JFETs, etc.
The most important factors to consider are an adequate heat sink and patience in setting up the bias and offset voltages.
Old 9th March 2010, 03:49 AM   #7287
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
I think that accurately covers the subject.
Old 9th March 2010, 03:52 AM   #7288
Blues is offline Blues  United States
Blues's Avatar
Originally Posted by jackinnj View Post
I think the results were only a gnat's hair better -- ...
Thanks!
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 9th March 2010, 09:51 AM   #7289
thank you for detailed explenation. I can start my iron now, can't wait to listen to it.
M.
Old 9th March 2010, 04:25 PM   #7290
Renron is offline Renron  United States
Renron's Avatar
Amen to that brother Jack!
Question for the masses:
Do anyone else's heatsinks just barely get warm?
I haven't scanned them with the laser temp gun, but when I put my hand on them after hours of playing they are barely warm. Is this nOrmaL?
R11 / R12 .59V with DC offset at ~+/- .05V that fluctuates a little as it warms up.
Silent as a snowflake.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
