Old 24th February 2010, 04:21 PM   #7181
Snokker is offline Snokker  Netherlands
Snokker's Avatar
Originally Posted by sekess View Post
Hey Snokker,
I did not realize that too much capacitance could result in buzzing. I just thought it creates start-up issues.
Thanks,
Steve
Hi Steve,
The capacitance you add at the secundairy side of the transformer causes a reactant current, 90 degrees ahead of the voltage. As the transformer itself is mostly inductive it interacts with this current.
Be aware of a cos phi > 1 (I think you use pf, powerfactor) at the primary side of the transformer. This means that the capacitive reactance is bigger then the inductive; Too much elco's on a too small transformer.
This can cause instability (underdamping) on the mains. This is often the cause of buzzing transformers.
For more info check "electrical reactance" on wikipedia!
Have fun!
Old 24th February 2010, 05:02 PM   #7182
sekess is offline sekess  United States
Interesting Snokker -- I'll have to look into this.
Thanks,
Steve
Old 24th February 2010, 05:06 PM   #7183
for 240Vac soft start I put ~50r in the primary circuit and timer bypass it at ~300ms.
For the slow charge I would prefer to use a Thermistor. It reduces the initial current when the voltage difference is high and the Thermistor is cold. As the voltage difference reduces, due to charging the capacitors, the thermistor has partially heated and allows more current to pass than if it were cold. Finally as the ClassA amp draws bias and the caps are almost charged the Thermistor should be quite warm and the resistance value low enough to simply relay bypass.
The heating Thermistor and the reducing charging voltage will give an approximation to constant current charging.
I would guess that somewhere between 1 and 10seconds would be appropriate. Test it and tell us how it performs.
A couple of sensor resistors placed appropriately and a two channel sound card to produce a couple of graphs would be very illuminating.
Old 24th February 2010, 05:13 PM   #7184
Originally Posted by bear View Post
Right, absolutely necessary.
I'd suggest 50watt wirewound ceramic resistors at minimum.
You can get away with less, but in the event something goes wrong or delays your relay you will smoke smaller resistors.
A value around 8-10 ohms is likely to be good.
With the lower voltages maybe a higher value will suffice...
I would only put this before the transformer at the primary.
Also, do NOT use a single relay contact. Use multiple high current contacts, imo. If you just have to use a medium size "cube" relay, at least get one with 4 contacts...
My Symphony No.1 amp has 500,000ufd @65vdc rail voltage. That and >2KVa of iron... so I use very large P&B relays. You can see a pic on my website if you hunt down in the amplifier section a bit...
As I said you can figure out the time thing after you put the supply together and have it running... just look at the pulse when you bypass it... that and the time it takes for the rails to come up. On my amp I used 10 seconds... more than sufficient to bring up the rails and let the amp stabilize (no speaker relays, so don't want thumps)
I'm thinking that a soft recovery type rectifier will be best in consideration of the current waveform that will be charging the cap banks...
How many caps to achieve this total capacitance??
_-_-bear
Hey Bear,
1. That's a very nice looking amp on your site.
2. I was wondering if I would have to use relays on the speaker outputs if I use a long delay on the soft start. I was going to see if there was any appreciable dc on the outputs during the start-up. If there was, I was going to use relays. Hopefully there won't be so that I do not have to use muting relays.
3. My amp is going to be dual-mono. Each of the power supplies has a 600VA transformer - followed by a soft recovery rectifiers - followed by the caps and chokes. I have 4 caps in each power supply. Each cap is 68,000uF.
Thanks,
Steve
Old 24th February 2010, 05:21 PM   #7185
Hey Andrew,
I too use 240V mains for my amps. I ran a 240volt line just for the amps. The rest of my components are on a 120V line.
So just to be clear Andrew, you would place the thermistors on the secondaries of the transformers and not on the voltage rails just after the rectifiers?
I would love to give you some graphs of the results. But I do not follow exactly how to set up the test. If you could be more specific, I would love to accomodate when I complete the project.
Thanks,
Steve
Old 24th February 2010, 06:42 PM   #7186
ichiban is offline ichiban  United States
space charged
ichiban's Avatar
Default Anyone, 240VAC, sonic benefits
Can anyone comment on the sonic pluses of using 240V vs 120V input to xfmr.
Old 24th February 2010, 06:45 PM   #7187
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 24th February 2010, 07:11 PM   #7188
expert in tautology
bear's Avatar
In the USA the 240vac line is going to be "stiffer" all other factors being equal.
Also the residual c**p (noise + glitchies) will tend to be common mode (on both legs) so the result is that they will often be canceled in the primary of the transformer.
[For the non N.A. readers, in the USA 240vac is 120-0-120, not 240-0]
_-_-bear
PS. in the USA you need 4 wires to meet code. 120, 0, 120 and SAFETY GROUND!
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 24th February 2010, 07:11 PM   #7189
a.wayne is offline a.wayne  United States
a.wayne's Avatar
This guy knows ... 2.47 in and you will have your answer ...
YouTube - Greek Audiophile
A man should look for what is, and not for what he thinks should be. -Albert Einstein
Old 24th February 2010, 07:13 PM   #7190
a.wayne's Avatar
_-_-bear
2 phase or 3 ?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
