| Thread Tools | Search this Thread |
#7171 |
Hey Andrew,
Couldn't you slow charge the caps from the primary or the secondary side of the transformer? What is the advantage of doing it from the secondary side? Thankls, |
#7172 |
Hey Andrew,
Plus, it's a bit of a pain slow starting from the secondary side. With two power supplies (for dual-mono), you need 4 resistors (one on each of the secondaries), which all have to be bypassed with either a 4-way relay or multiple relays. If it's doable from the primary side, you can do the whole thing with one resistor (or combination of resistors) and one relay as long as the ratings are high enough. Now for that matter, if you plan on slow starting from the secondary side, wouldn't it be even better to slow start from just after the rectifiers. this way the rectifiers never see a shhort at start-up? Thanks, Steve |
#7173 | |
The machine inserted Panasonics are specified to be mounted 16mm (about 5/8inch) above the PCB. The Ohmite TWW5's are very efficient at getting the heat off the board. They aren't quite as flat as the Panasonics or Dales, but are rated at 5W. There was a brief period of time when Ohmite switched over to ROHS and they were out of stock at all the usual suspects. Janneman appears to have used them in one of his designs for Elektor. I have gotten my 576 curve tracer to smoke on occasion. sometimes you can make the current limiting resistors unhappy. |
#7174 |
I was going to bring up the 10 ohm resistors... hadn't gotten there yet.
So, maybe 2 x 20ohm 1/2w then? sekess, if you put a resistor in series with the primary (the usual way to go) for a soft start the caps will never fully charge because of the vdrop of the resistor...fwiw. How long before you throw the relay shorting out the series resistance depends on the resistance and the amount of capacitance you have to charge up in the real world. A little bit of experimentation will be sufficient. Watch an ammeter in line or else look to see if the house lights blink? Of the many ways of doing the switching are the RC + transistor, 555 timer, manual switch, and comparator that looks at the rail voltage... _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#7175 |
Hey Bear,
Yea, I know while the resistor is in place the rail voltage won't reach 24 volts. But, the caps will stop charging at some lower voltage. then, when the resistor is switched out, the rails will reach about 24 volts and the caps will finish their charging. Basically, I am trying to figure out the following (for soft-starting and slow-starting): -- What size resistor(s) to use - both voltage and wattage -- Where to place them - primary, secondary, or at the rails -- How much time before I bypass them with the relay If practical, I would like to soft start as well as slow charge the caps (as Andrew T has alluded to). I got a decent deal on some very large caps. So, I wanted to try those guys. I am going to end up with 280 000uF per power supply (dual-mono -- so 560 000uF total). With that amount of capacitance, I thought it would be best if I could slow-charge them at start-up. Thanks, Steve |
#7176 |
#7177 |
Right, absolutely necessary.
I'd suggest 50watt wirewound ceramic resistors at minimum. You can get away with less, but in the event something goes wrong or delays your relay you will smoke smaller resistors. A value around 8-10 ohms is likely to be good. With the lower voltages maybe a higher value will suffice... I would only put this before the transformer at the primary. Also, do NOT use a single relay contact. Use multiple high current contacts, imo. If you just have to use a medium size "cube" relay, at least get one with 4 contacts... My Symphony No.1 amp has 500,000ufd @65vdc rail voltage. That and >2KVa of iron... so I use very large P&B relays. You can see a pic on my website if you hunt down in the amplifier section a bit... As I said you can figure out the time thing after you put the supply together and have it running... just look at the pulse when you bypass it... that and the time it takes for the rails to come up. On my amp I used 10 seconds... more than sufficient to bring up the rails and let the amp stabilize (no speaker relays, so don't want thumps) I'm thinking that a soft recovery type rectifier will be best in consideration of the current waveform that will be charging the cap banks... How many caps to achieve this total capacitance?? _-_-bear
#7178 | |
#7179 |
Hey Snokker,
I did not realize that too much capacitance could result in buzzing. I just thought it creates start-up issues. Thanks, Steve |
#7180 | |
| Currently Active Users Viewing This Thread: 4 (2 members and 2 guests) | |
| Dennis Hui, Bksabath |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.20802 seconds (70.41% PHP - 29.59% MySQL) with 11 queries |
