#7091 |
Some members account that the amplifier sounds " bigger " more "dynamic" with out thermisters , could it be due to this "feedback" effect?
A man should look for what is, and not for what he thinks should be. -Albert Einstein |
#7092 |
the thermistor feedback is very slow, many seconds of time constant, maybe minutes.
It will not be audible from millisecond to millisecond, nor even from second to second. However, it achieves this stabilisation by changing the Vgs for different operating conditions. It is quite likely that the amp will have a different bias current when the ambient conditions are different. This may be audible from morning to evening, or day to day, or season to season. It will depend on how sensitive the amplifier sound is, to changes in bias current. |
#7093 | |
#7094 | |
My heatsinks run very hot, I can only touch them for 4-5 seconds, I guess I'm not missing anything not having used them???? My build seems to warm up fine and hold steady bias.
"Some lures are designed to catch fish, others are designed to catch fisherman." |
#7095 | |
My main concern is the heat, I don't know if the heatsinks I'm using are big enough.
#7096 | |
Im sure you can make the 6 seconds needed ![]() Anyway, might be worth to consider how accurate measurements really are I suppose you measure voltage drop, and not actual current flow |
#7097 |
Thank all for the replies.
I have the thermistor behind a soft start board that i bought from Connexelectronic.This is on the primary side of the transformer. i have used this set up for the past one month . I check that the maximum operating temperature of the CL 60 is 175 deg c . I think CL 60 will be ok I might try danny's soft start circuit one of this days. BTW, my current set up with the F5, OB5 from GR research, Promitheus DAC and AMC CD 6 player as transport is the best in my 20 over years of hi fi journey. This set up is good in all aspects and I think I am spending too much time listening to music ! thanks again to all the helpful people. kp93300 |
#7098 |
When using a soft start, the CL60 becomes redundant...
#7099 |
This is what I thought but I was advised by the soft start board manufacturer to use the CL 60 thermistor in addition .
The soft start board is a relay mechanism with the delay timing regulated by a cap. kp93300 |
#7100 |
I would get rid of it.
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
