Old 13th February 2010, 03:02 PM   #7051
bobodioulasso's Avatar
When you double the load value , the power halves.
Old 13th February 2010, 03:31 PM   #7052
sekess is offline sekess  United States
umut1001 -- I thoght with +- 24v volt supply - you have 48v. So, 48/16 would give you 3 amps.
bobodioulasso -- the power halves when you double the load value when you are looking at power from the max voltage obtainable (V*V)/R. But if we are looking at power from the current (I*I)*R, Power would theoretically double with doubling of the load. However, voltage is going to limit that number. I think?
thanks,
Steve
Old 13th February 2010, 03:38 PM   #7053
In a voltage point of view, about 20 volts are available. 20 x 20 /2 x16 = 12.5w
The current capability does not overpass this law.
right
Then , with a 16 ohms load the bias current can be halved to suit the voltage capabilities.
Old 13th February 2010, 04:05 PM   #7054
bobodioulasso --
From the manual:
"The power of 2.6 amps into 8 ohms is I*I*R, or 2.6*2.6*8=54 watts. This is the peak value, and the nature of an undistorted sine wave is that the peak wattage is twice the average, so this circuit would operate 27 watts average Class A into 8 ohms. At currents above 2.6 amps one of the transistors will shut off, leaving the other to continue to increase beyond 2.6 amps in what is known as Clas AB."
So, if I substitute 16 ohms for the 8 ohms used in the equation above, 2.6*2.6*16=108watts peak and 54 watts average.
However, you are saying that only 20 volts are available (20*20)/2. If this is the case, then you are answering my original question which was: how much voltage is available?
Why are we dividing the voltage rails by 2?
Thanks,
Steve
Old 13th February 2010, 04:09 PM   #7055
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Where to buy Kendeil caps in the US ?
Old 13th February 2010, 05:16 PM   #7056
bobodioulasso --
sorry, didn't mean to say "why are you dividing the rail voltages by 2"
what I mean to ask is:
1. why is there only 20 volts available and not the entire rail voltage differential?
2. why are you dividing the voltage squared by 2 in your formula for wattage?
Thanks,
Steve
Old 13th February 2010, 05:27 PM   #7057
1-The mosfets when turned on still have a residual voltage across them and some voltage is lost across the source resistors.(what Jacco was formulating)
2- Power is calculated from Vmax/1.414
Old 13th February 2010, 06:07 PM   #7058
a.wayne's Avatar
supply out or amplifier out ?
Old 13th February 2010, 06:08 PM   #7059
ok bobodioulasso,
So, if I'm following you correctly:
-- Let's say you've got +-24 volt rails. That would give you 48 volts total.
-- Let's take off 8 volts for various losses. I'm not sure if this is a good approximation or not. I just chose it so that we have an even 40 volts available at the rails.
-- So, if we have 40 volts as Vmax, we can now divide by 1.414. This would give you 28.29volts.
-- Now, using (V*V)/R as the calculation for Power, we get (28*28)/16 = 49 watts.
So, I'm getting 49watts. Where is my error? Do we lose more than the 8 volts I chose to subtract from the rails?
Thanks,
Steve
Old 13th February 2010, 08:35 PM   #7060
Efficient voltage is Vmax/<2 (what you read on a voltmeter) = 20v in our case
<2 = root mean square of 2
P=(Vmax/<2)(Vmax/<2) /R= (Vmax x Vmax)/2R
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.18855 seconds (69.56% PHP - 30.44% MySQL) with 11 queries
