Old 8th February 2010, 08:34 PM   #6991
cviller is offline cviller  Denmark
cviller's Avatar
Nice.
But you need to make sure to get plenty of airflow along the fins.
Or you could make a powerhouse like this:
I have started a blogged guide to my F5 boards read it here: F5 pcb v2 blog
Old 8th February 2010, 08:45 PM   #6992
a.wayne is offline a.wayne  United States
a.wayne's Avatar
^^^^ Is that your new BA-2 ? ................
Old 8th February 2010, 09:46 PM   #6993
bear's Avatar
erpii, I think you will need to blow air if you enclose the fins like that.
For natural convection one needs to maximize the airflow, otherwise you have to derate the heatsinks by quite a bit - which means the amp will get too hot, which means the thermistors will cut back the bias, which means it won't be in full class A anymore...
...and I think one might consider putting the board into an "H" configuration... let me try ascii:
O O
| | <---heat spreader "bars"
------ <---pcb
O O <--round heatsinks (not to scale)
EDIT: when I post the spaces get chucked and the drawing squishes left justified - use your imagination??
You could use 3 per line also... and the distance between the heatsinks is only because of ascii drawing...
I dunno...
_-_-bear
_-_-bear
http://www.bearlabs.com ...live within ~60mi of Albany NY? contact me! --
Old 9th February 2010, 01:53 PM   #6994
udailey is offline udailey  United States
Passive Aggressive
I wish I had info to share but they have not got back to me yet. However I have to agree with bear. Airflow may be necessary. I dont think it will need much though. Even a breeze will help A LOT. Computer fans are getting very very quiet. I recently got one for about 4 bucks to waft away solder fumes. Running it on a battery and a pot. I cant hear it at all even two foot from it. I would put them below pointing up. I think it would do it because I think those sinks are less than you need but not far from what you need.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 9th February 2010, 02:15 PM   #6995
a.wayne's Avatar
Uriah
Agree ! My intention is to run fans also ....
Old 9th February 2010, 02:22 PM   #6996
bear's Avatar
My LR is dead quiet.
I am in the country.
60Hz. transformer hum can seem deafening late at night especially in the winter when there are no bugs to make outside noises.
Fans are problematic. At least have the fan operation controlled by a thermistor for speed control or worst case a thermal switch or two with either resistor or control of the set pin of a 3 pin vreg so that it is quiet until it gets hot...
The quietest fans are "squirrel cage" blowers. You'd want one that is oversized and then run it way below it's intended speed, like crawling around.
I am considering doing just this via something like a clock motor or other very quiet low RPM motor and run the blower via a rubber "O ring" belt for decoupling ... not much breeze is a lot more cooling than natural convection...
_-_-
_-_-bear
Old 9th February 2010, 05:08 PM   #6997
Originally Posted by bear View Post
...other very quiet low RPM motor...
Hi bear,
what do you mean?
Maybe something like that:
Scythe Kaze Jyu Slim 1000, 100x100x12mm, 1000rpm, 25.58m³/h, 14.5dB.
Old 9th February 2010, 05:13 PM   #6998
umut1001's Avatar
Has anyone tried using audio input transformer with F5?I do not know much about audio transformers but my friend said that it is better than using capacitors.I have a laptop that have headphone output.If i use transformer with x3 gain how can it be? Which transformer can i use 10-20$ price range ?thank you
107H Hammond Miniature Epoxy Potted Audio transformer - eBay (item 180398802167 end time Feb-15-10 22:32:28 PST) Is it reliable?
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components
Old 9th February 2010, 05:30 PM   #6999
labjr is offline labjr  United States
The F5 doesn't have a capacitor input. Why do you want to use a transformer?
Old 9th February 2010, 05:33 PM   #7000
umut1001's Avatar
Ok sorry.It is only for gain.My laptop has headphone output but it is not enough.I need to get 3-4x gain
Currently Active Users Viewing This Thread: 5 (2 members and 3 guests)
Mixon1, coils
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.19808 seconds (69.50% PHP - 30.50% MySQL) with 11 queries
