| Thread Tools | Search this Thread |
#672 | |
The one and only
Both are push-pull complementary feedback pairs with voltage gain. That said, the details of the circuits and the performance are different: Vertical vs Laterals, the amount and arrangement of feedback, the bias values, the power supply values, how the adjustments are accomplished, the power rating, damping factor, gain, and distortion. They do appear to have about the same bandwidth. Also the circuit appears in two different Selectronic products, one a 4 channel amplifier designed to accommodate bridging, and another a monoblock with a chip for a balanced input. I'm sure they are both fine sounding amplifiers. |
#673 | |
copy for your son.
#674 | |
it's settled, she loves me, 7/10 |
#675 | ||||
Give me a day or a week or a month...or something. I've been wearing my farmer hat today (tomatoes, peter peppers, basil) and about a hundred other things, plus I'm trying to find time to put the second installment of How's The Stupid Thing Work? in the GR-25 thread. In the meantime, you could do worse than to put something like 100 Ohms in series with each side of your headphones. Depending on what headphones you have and their sensitivity, you might look to adjust those values up or down after trying it. Yes, you're killing your damping factor, but face it...there's not a lot of mass in a headphone driver. It doesn't need a lot of braking to get it to stop. It's only 21:30 here, but I'm toast. Heading to bed ASAP. I'll drag out the schematic and take a look tomorrow or Monday and see what I can see. Grey |
#676 | |
If you need to know it, I'm driving 80 ohm headpones at the moment (beyerdynamic DT770Pro). Admittedly, i listen to them more than speakers since I have a flatmate with a different schedule than I. Thanks again! -Jared |
#677 |
While waiting for the Fairchild EU group buy, which is forcast now from Digikey to be 10 weeks (!!! ), we have got a few Toshiba 2SK1530's / 2SJ201's to play with. The pdf attached plots drain current vs Vgs referenced to bias point, with both values inverted for the P-device to ease comparison. The bias current is 2A for both FETs, Vgs is 2.38V for the N-device, and -2.30V for the P-device. Transconductance at bias is about 4.5 S. Red line is 2SK1530; light blue crosses are 2SJ201. It was a hell of a job to make the two sets of data visible from one another in excel. A picture says a thousand words. Patrick |
#678 |
I am planning to build a high power version of F5 which uses my existing +/- 35V rail supply, I have add an resistor at the drain pin of the JFET to lower the voltage it see. I ran a simulation and things seem ok. Do you think this schematics would work?
My Audio Page |
#679 |
Why wasting voltage with resistors? You could use a cap multiplier for about the same drop with a far better filtered rail as bonus!
Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets F5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#680 | |
Living la vida loca ?
Looks like Sponge Bob has killed another thread. |
| Currently Active Users Viewing This Thread: 5 (4 members and 1 guests) | |
| extrip, arche13, brainf, c_door |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.18589 seconds (63.44% PHP - 36.56% MySQL) with 11 queries |
