Old 16th January 2010, 09:48 PM   #6661
EUVL is offline EUVL  Europe
> That's one. I can think of a couple others...
Let me make a fool of myself :
Connect the source of Q1 & Q2 on each (left or right) half together, then connect these two junctions across the two halves with a 10R resistor. The feedback resistors are then 25R and goes from output to the source junction. Non-inverting then.
According to John Curl, this "H" diff pair has very good distortion cancellation.
Patrick
Old 16th January 2010, 10:58 PM   #6662
Hello
Please try to use GR type .
Greets.
Old 16th January 2010, 11:23 PM   #6663
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
No , Patrick - that's my job usually ......
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 17th January 2010, 12:22 AM   #6664
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
Originally Posted by umut1001 View Post
I do not have low idss jfet.All of them are above 8ma.Does not them work well ?
They will work very well, but are "over qualified". Keep in mind 2SJ074s are very hard to find nowadays. The F5 has P & N ch jfets at the input so high Idss jfets are not necessary.
GR and lowish BL jfets will work very well too.
I am matching BL jfets and will soon make some available to diyers. Some appear to be in the 6 to 7mA range.
Old 17th January 2010, 10:31 AM   #6665
bobodioulasso's Avatar
Originally Posted by wensan View Post
Oh! I am wrong.
Most of signal will be amplified without feedback control.
Thx Wen-san, i understand my mistake now.
It seems there is no way to keep the 2 ways NFB with a symetrical input.
It has to be as follows. But nothing new then.
Old 17th January 2010, 10:32 AM   #6666
generg is offline generg  Germany
generg's Avatar
Would be great to have a solution!
I dontīt want to double all components only to test balanced driving.
I was also looking about an hour over the different possibilities, but I am not experienced enough. No clear result.
Thank you bobodioulasso for trying to get the answer!
and the First Wtt is......a really First Class Idea Mr.PSS
Old 17th January 2010, 10:42 AM   #6667
Neither to have a lot more dissipation.
Old 17th January 2010, 10:48 AM   #6668
generg's Avatar
Exactly!
Old 17th January 2010, 05:04 PM   #6669
So its Showtime for my F5!
I got it hooked up via a 100watt lamp and all seems fine. All the voltages are present, and everything is stable.
I do however measure like 8mV on r12 and r 11 for the bias.
After turning the potmeters for quite some time I suspect something is wrong.
I meseured r3 and r4 and they give about 8 ohms.
Is it possible that I have to turn quite some more (slow pots?)
Old 17th January 2010, 05:18 PM   #6670
tinitus is offline tinitus  Europe
Rikkert, be certain that you measure correctly
Does amp get hot or not ?
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
unixdeveloper, Oreda, rothay, hofer
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.20000 seconds (63.22% PHP - 36.78% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
