F5 power amplifier
F5 power amplifier
Old 14th January 2010, 04:26 AM   #6601
cviller is offline cviller  Canada
cviller's Avatar
The F5 has high input impedance, so you should be able to drive it with almost anything, but to you question regarding sound quality of soundcards, you would probably get more educated answers in the computer source section.
Old 14th January 2010, 04:28 AM   #6602
umut1001 is offline umut1001  Europe
umut1001's Avatar
I tried driving F5 with my soundcard but i couldnt get good sound.It needs preamp or buffer.I will write there too.
Old 14th January 2010, 04:34 AM   #6603
cviller's Avatar
I have the emu 0404, probably same output stage and it drives the F5 just fine. Is your sound distorted to too low. If distorted, try to play around with all the different volume settings on your sound-card and pc.
Old 14th January 2010, 05:12 AM   #6604
sangram is offline sangram  India
Originally Posted by umut1001 View Post
Hi.My soundcard is emu1212M.I think it has several hundreds of output impedance.And i think i should use a preamp/buffer(maybeB1 buffer) to drive F5 amp.And there is another way.To buy a AUDIOTRAK Prodigy HD2 soundcard.It has headphone output and good enough to drive F5 amp.Which way is better? Is it a good technic to drive power amplifiers with headphone output of soundcards?(not to use a preamp/buffer and signal cables and I think it can be better for sound quality.because of short signal path and less components.
I use the same card myself. It is able to drive the f5 to max output if set to 4db in the i/o control panel. It works without any issues, but the amp clearly points out the entry level source. The difference between this card and the buffalo is pretty staggering.
My card is modded with black gates and opamps. Much better than stock, but easily beaten by a good dac. As long as the source is able to push about 5 volts, it should be fine. Most pro cards will do 4v no problem.
Old 14th January 2010, 01:23 PM   #6605
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
You can tweak the gain on the F5 by increasing the value of the feedback resistors, but you have to re-bias the amplifier etc., etc. and the distortion will be different.
Old 14th January 2010, 01:38 PM   #6606
umut1001's Avatar
ok i will try.and one question.If i increase the gain does input and output impedance changes ? thanks
Old 14th January 2010, 03:07 PM   #6607
umut1001's Avatar
In the past i did not know +4db of the card and i could not get high power from F5 amp.The soundcard was distorting.I changed njm opamps with lm4562.The specifications of card is very good and you say that a good dac can beat it.How ? I see that most dacs does not have as good specification as emu1212m.I think i will use elna silmic 2 to mod capacitors.Is it worth to do?Can you show me your mod on another topic or email me the pictures?thank you
Old 14th January 2010, 03:12 PM   #6608
umut1001's Avatar
And when i measured i saw that the leg of opamps have supply of +-12volts
Old 14th January 2010, 03:13 PM   #6609
I use the Buffalo (version 1). The version 2 is even better, supposedly, but a little too $$$ for me.
1212m uses a CS4398 - by any standards, easily beaten by PCM179xx, Sabre and Sabre32. A friend recently compared a Essence STX (PCM1792 and stuffed with exotics) and it beat out the 1212m pretty easily.
With most amplifiers, the difference is very small but with the F5, it becomes really easy to spot which card is playing. The +4dB is set from the I/O control, not in the front mixer page - it will distort if you push the sliders to +4dB. Leave the mixer at default levels, and use the monitor control for volume. For further discussion, email me - I'll send along the pictures in a few days - will have to dismantle the entire audio rack to pull out the PC.
Old 14th January 2010, 04:57 PM   #6610
umut1001's Avatar
my notebooks sound card is internal Realtek HDMI Output.Is it better than emu1212m? maybe can have a better chip?
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
