| Thread Tools | Search this Thread |
#6551 | |
The jig adds about 10 milliohms to the impedance. The macro can be downloaded from AP's website -- it's one of those VBA's so you'll have to download the 2700 software first and run in demo mode. It's not like VB where you can "deploy" a project. |
#6552 |
I took out my capacitor bank -- which was some computer grade Mallory's -- replaced with the Zen like CRC supply (30,000uF 4x 0.47R, 30,000uF), moved the transformer onto the front panel -- the noise is a trifling 43uV 22Hz -- 22kHz, 9uV "A" Wtd.
#6553 |
... now try some Epcos B41560s (33,000uF) or if the budget can stand it, some B41550 41570) Sikorels - a step up again.
I do use some bipass Sikorels (Audionote, California - eBay), but usually end up having to add some snubbers as many bipass efforts tend to create extra osc, etc. can be a real PIA! Really appreciate your site - good to know your facilities, products, kits, matching available, and esp at the prices - many thanks.
... jh |
#6554 |
#6555 |
Hello JackinnJ,
are you able to show square and Sinewave (20hz/1K/20K ) outputs @ 20 Watt regards, |
#6556 |
5w is lower than 1 watt??
_-_-bear |
#6557 | |
How close were the bypass caps to the PCB? I recall NP saying they should be 6" or more away to prevent oscillations. |
#6558 |
5W is red. I think I got it right. Aaats raight as Liza Doolitle was wont to exclaim to Prof. Higgins!
This is a bit of a compromised F5 -- there are caps to limit RFI on the JFETs inputs and I matched the input gatestoppers to their input capacitance, I found it helpful to put some joules on board in the form of Elna Silks. This is one great sounding amplifier. It's the Occam's Razor of Amplifiers! |
#6559 |
Hi Alzira,
Yeah, I wondered about that too, as I like to bring the power supply as electrically close to the "work place" as possible but anyway, I looped 'em up a bit to have about 8" leads (double 1mm 4-9s Si wire) and no problems. I was rather curious just how far I could effect the amps performance/sound by going a bit over the top with this bipass and snubber "stuff" - I think it's a bit different again when the amps go into AB mode, something about changing the balance of the harmonics and the bipass caps characteristics effect the sound more, for better or worse. [IMO, that is!] I have Cmultipliers on the rails now (extra volts on trannie) and surprisingly, changes to the diodes/supply caps still directly effect the sound of the amp. Rather interesting, these "simple" amps!
... jh |
#6560 |
Hello,
Here I attached a photo of my F5 square wave picture @ 20kHz (approx.10R dumb load) and the original square wave @20kHz directly from generator to scope. Also for compare here is Leach amp square wave picture@ 20kHz. What causes these peaks F5 picture? Is it a generator failure which is old maybe? Or, f5 does not work as is necessary>? Sound of my F5 is great IMHO. Thanks in advice. |
| Currently Active Users Viewing This Thread: 5 (4 members and 1 guests) | |
| unixdeveloper, Oreda, rothay, hofer |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.19332 seconds (62.82% PHP - 37.18% MySQL) with 11 queries |
