| Thread Tools | Search this Thread |
#631 |
So, which of the 2SK170/2SJ24 versions is more suited to the F5 schematic as proposed, GR, BL or V? I know this is a silly question but to tell the truth, its the first time I am dealing with Jfets and I am getting a little confused here.
I am sure that Mr. Pass specified everything (as usual) in his article in AudioXpress, but in this part of the world the May issue is not yet available and I am already gathering parts... Thanks |
#632 |
No GR !
Looks like Sponge Bob has killed another thread. |
#633 |
#634 | |
The one and only
shorted and Vds at 10V. BL is the preferred part, but you can use GR if you raise the Drain resistance. Currently its a 5K pot, in parallel with a thermistor plus 2.2K in parallel with a 2.2K. You can remove the 2.2K. Alternatively you can consider paralleling JFETs to get the current up. |
#635 | |
..........Naah. (howcome, even in walnut veneer i see naked women?)
#636 | |
Official Court Jester
they are sad
my Papa is smarter than your Nelson ! tnx to |
#637 | |
#638 | |
Taking the risk to appear publicly too stupid… Why V grade with a lower R wouldn’t work? I'm afraid that it would reduce the open loop gain, but the same goes for GR the other way round (I mean increase the OLG with GR). Best regards. Philippe. |
#639 | |
So you're offering a group buy od 2sk147 The answer to your question may be due to Jaccolina Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#640 | |
The one and only
reasons. 1) try and find any, and if you do, save them for phono stages 2) I want to limit the current to about 8 ma through the circuit to avoid too much dissipation in the JFET. Of course you can use a greater value than the 10 ohm for the feedback, but you can just as easily get by with a BL. |
| Currently Active Users Viewing This Thread: 4 (2 members and 2 guests) | |
| jwor, chchyong89 |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.16978 seconds (60.41% PHP - 39.59% MySQL) with 11 queries |
