| Thread Tools | Search this Thread |
#6191 |
isn't it 1.3 amps per device, or 2.6 amps bias per channel?
To return to Oz we've fled the world with smiles and clenching jaws - SS |
#6192 |
Official Court Jester
that's the case for circlotron , where you have two PSUs , but F5 have just one .
1A3 , going from + to - , or vice versa , whatever
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
#6193 |
:-( now i'm confused again.
I guess it is (1.3 amps per device @ 24 volts) x2 which is 1.3 amps total at 48 volts? Class A operation up to 2.6 amps output? I thought I understood but now. . . Maybe it's the ambien
#6194 | |
I max = 2x I bias into the load. 2.6*2.6*8 = 54.08 watts There are 27 watts pure class A into 8 ohms. (54watts max) Read the PDF and Zen articles again. PP Class a amp works like this: When idle the two halves run equal current: the bias. Each half runs its current through the load but as they are equal and in opposite direction the load see no current. When a signal is applied, current varies the same quantity into the two halves but opposite .One side increase while the other decrease. This variation's amplitude is from bias value to twice this value and then to zero. When one side is 2xbias, the other side is zero. This explains why one leaves class A at 2xbias. Last edited by bobodioulasso; 4th December 2009 at 07:15 AM. |
#6195 |
A short pic...
#6196 | |
If the load is 8r0 then the maximum ClassA power is 27W ([2 * 1.3]^2 * 8 / 2)
regards Andrew T. |
#6197 | |
Your description confirms you do not understand how push-pull ClassA operates. BTW, 27W is equivalent to 54Wpk. i.e. both are 20.8Vpk and 2.6Apk into 8r0.
regards Andrew T. |
#6198 |
#6199 |
I was thinking about a situation where the amp goes into AB (without feedback) and the Pch and Nch devices do not have curves that perfectly overlap so the area where one goes into cutoff does not track exactly as cutoff is reached, the cutoff is reached and the driven transistor is the transfer curve that continues.
Note to self, good idea: don't post in the AM before being fully awake...
_-_-bear http://www.bearlabs.com ...live within ~60mi of Albany NY? contact me! -- |
#6200 |
...When one half runs more than 2.6A ,which can be the case with less than 8 ohms loads, or even 8 ohms reactive ones, the other half is cut off. Then that is classAB mode.
Thanks Andrew to repeat what i did just say. Last edited by bobodioulasso; 4th December 2009 at 04:07 PM. |
| Currently Active Users Viewing This Thread: 5 (4 members and 1 guests) | |
| zephyr, nick5, UKToecutter |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.24054 seconds (47.84% PHP - 52.16% MySQL) with 11 queries |
