Old 5th May 2008, 07:10 PM   #611
One of the most valuable things you can do when you're laying out a PCB is to put it down and come back to it the next day. Better still, two or three days later. You'll see all kinds of things that can be done better. Sometimes you even catch mistakes.
Grey
Old 5th May 2008, 07:45 PM   #612
jackinnj's Avatar
and when you mount the power resistors -- put them at least 1/4 to 1/2 inch above the board as they are gonna be cookin'
Old 5th May 2008, 08:04 PM   #613
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
It sems that the power resistors could be spread apart a bit more to help with cooling...
Old 5th May 2008, 08:34 PM   #614
Audiofanatic's Avatar
Grey
I second that!
Audiofanatic
Be nice to animals.
Old 6th May 2008, 01:56 AM   #615
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by twitchie
I'm just not looking forward to the next part - drilling holes.
With any luck ( and wife + 2-year old permitting), I may just have this thing stuffed and singing before summer's over
Thank you Nelson Pass for your immeasurable contributions to this hobby!
Drilling PCB's is a walk in the park.
I would not change anything, but simply just stuff the boards, and see IF any problem at all should arise, but I doubt it should cause you trouble.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 6th May 2008, 03:26 AM   #616
Formerly "jh6you". R.I.P.
Babowana's Avatar
As I am seldom satisfied with my own PCB work, I do approach in
different way. I darw all paths on the paper with pencil and check
them wether all are going to right directions and branches.
And, if I am sure of that, I just make the PCB and finish all at the same
time. I do not want to cry over my ever-ugly PCB works...
But, the impovement is possible for the second try... third try...
Old 6th May 2008, 01:57 PM   #617
RIP
Hey Twitchie,
I've been studying your board layout and you've done a fine job, but I found a little error in the feedback loop. R1 and R2 should be 10 ohms, not 10K, and should probably be 3W also.
I'm still looking but nothing else jumps out at me right now.
Also, on the traces around the 240, it would be better to locate R14 much closer to the gate pin and pass the source trace under it.
Keep it up, you're lookin good.
Bill
Old 6th May 2008, 05:48 PM   #618
sandstorm33's Avatar
Once the music starts where's UGLY then???
Twitchie..no need to make the 10ohm resistors 3w. The rest should work just fine. If you do it again consider allowing for choices on the source resistors..I for one have LOTS of Dale 5watters. Also slightly larger pads on the smaller traces aids in solder flow. Good job for the first try.
Old 6th May 2008, 06:03 PM   #619
jackinnj's Avatar
Lateral F5 wiring layout:
Old 6th May 2008, 06:20 PM   #620
RIP
R1 and R2 pass significant current to ground, use at least 1W.
OHM's Law works every time, unless magic is involved.
Bill
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
brainf, ClothEar
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.17845 seconds (60.76% PHP - 39.24% MySQL) with 11 queries
