| Thread Tools | Search this Thread |
#6171 |
#6172 | |
I thought Nelsson could answer this..but no sign of him..
Regards Åke |
#6173 |
just wanted to get a concensus on where the thermistors should be placed. the way i have my board and mosfets attached to the heatsink give me two options. hopefully my photos can aid in determining what i'm talking about. it's hard to get a clear photo that is large enough!
the options are: 1. thermistor is in contact w/ the mosfet and 2 of its pins. it also touches the strip of aluminum i am using to clamp the mosfets to the heatsink. it seems to be electrically isolated still, but touches several pieces and is kind of wedged in there. no pressure is on it, but it's a snug fit (but still loose enough to slide in there easily). i have the leads covered with insulating sleeves. this is how i currently have things set up. 2. i could also position the thermistors "above" the circuit board and they could sit next to the aluminum clamping strip. my concern with this is that they won't be in direct line of the mosfet package and the aluminum strip might provide some thermal shielding so the thermistor doesn't have a good idea of what's going on. any ideas? |
#6174 | |
#6175 |
#6176 |
#6177 |
i got it now. those heatsink aren't going anywhere. i know my heatsinks will need to be reinforced.
#6178 |
enochRoot,
are those Bergquist K-10 pads isolating the MOSFETs? i realized last night that i don't have any TO-247 pads. i also found some TO-3 rectangular mica from Mouser that could be trimmed down as well. |
#6179 |
yes they are. i got sample sheets a while ago of both the K-10 and Q-Pad 3. i simply cut some squares out of the K-10 to use. i had hoped to use mica and grease as everyone seems to say they work better, but i could not locate TO-247 pads anywhere easily. since i am getting anxious for sound and i had this lying around, i figured it should be sufficient
![]() let me know if you want a square as i have plenty left and could drop some in the mail for you. Last edited by enochRoot; 2nd December 2009 at 10:16 PM. |
#6180 | |
| Currently Active Users Viewing This Thread: 4 (3 members and 1 guests) | |
| rothay, hofer |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.20945 seconds (68.49% PHP - 31.51% MySQL) with 11 queries |
