| Thread Tools | Search this Thread |
#6161 | |
Will a series cap do anything ? But probably not It doesnt in a speaker xover You say your trafo output have 1Kohm in series and 2.2nf to ground, as I understand it How does that work/couple with the F5 input, 1Kohm/100Kohm The paralel 2.2nf might worry me a bit But I really dont know DC related or what What will happen if you remove the 1kohm/2.2nf on trafo output ? Might it be a low pass filter to prevent passing on high FR problems, and that it really dosnt work well Because of the exstreme simplicity F5 might be somewhat sensitive to any ground coupling, but I dont know But maybe be a bit careful until someone with knowledge have evaluated this Last edited by tinitus; 2nd December 2009 at 12:32 PM. |
#6162 | |
cool beans guys, thanks. i've never had to deal with this amount of heavy thermal management before.
? good point, i can see where the base is restricting rising air flow. Last edited by fishski13; 2nd December 2009 at 01:29 PM. |
#6163 | |
But its a wild guess and depends on design But if you control and increase up upwards airflow in the "tunnel" you have between your heatsinks, it might be very effective as a "pull motor" fore outside flow Funny to think that even to close in the heatsink may improve airflow and effectiveness, if it can "breathe" properly Maybe some kind of cooling fluid inside the bottom of heatsink could be interesting if it would be "dragging" more fresh air But I suppose theres other simpler ways around it One thing To have the mounting surface machine planed If theres any possibility to have it done, do it Though, I have no idea how much the heatsink bents when its hot But now I think Im about to loose it, and just rambling too much Last edited by tinitus; 2nd December 2009 at 01:56 PM. |
#6164 | |
#6165 |
Anyone measure the ripple rejection ratio?
#6166 |
Anyone know where my son put my micrometer? I found the DMM and the socket wrenches.
#6167 |
The oven? Or maybe the fuel tank of your car...
#6168 | |
Others claim the old style isolators sound better than modern materials, who knows The ultimate way to use the copper "heat spreader" is supposed to work best if you mount devices on copper without any isolators By this its possible to mount an even bigger and better heat conducting isolator between copper plate and heatsink It might be pretty risky in terms of shorting through the mounting screw Honestly I dont believe theres much advantage due to the added complexity and connections, its probably just a winn and loose game I believe in proper dimensioning and smooth mounting, concervative and careful attention to complete design, thats all it takes Last edited by tinitus; 2nd December 2009 at 06:39 PM. |
#6169 |
What IS the recommended heat sink per channel people are using here? I see the Pass article specifies 8"x6" w/ 2" fins, 2 per channel. I see a few here only using one slightly larger for the whole amp. I just want/need 1 heat sink per channel. Is 8"x10" w/ 2" fins acceptable for each channel? I want as much heatsink as is beneficial.
Have thought of 10" x 12"x2", one on each side, one for each channel, but man the cost goes up! Should I just go ahead with 10x 12x2? I figure I need at LEAST 2 in the 8x10x2for a stereo amp, right? Please advise! I would also like enough in case I get the guts to do a balanced version.....Thanks! russellc Last edited by Russellc; 2nd December 2009 at 06:52 PM. |
#6170 |
outside, using them as a crescent wrench ?
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
| Currently Active Users Viewing This Thread: 5 (4 members and 1 guests) | |
| extrip, arche13, brainf, c_door |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.16287 seconds (62.49% PHP - 37.51% MySQL) with 11 queries |
