Old 30th November 2009, 05:19 PM   #6131
Originally Posted by Tyimo View Post
Hi Fishski13!
What are those "soldering pins"? Where did you buy it?
Greets:
Tyimo
they're called "turrets" and favored by guitar tube amp builders. they need to be "staked" from underneath by either a staking tool, or a center punch. i bought them and the red G-10 glass epoxy board here: Boards and Board Making Parts. i'm sure they would be fairly easy to source in the EU.
Old 30th November 2009, 06:06 PM   #6132
tinitus is online now tinitus  Europe
Originally Posted by Ryssen View Post
Yes,my problem was the amp got burning hot when the dac was connected.
Wasnt it transformer coupled ?
Could it be high inductive loading causing it ?
Or maybe your interconnects, both inside and outside ?
Old 30th November 2009, 07:18 PM   #6133
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Yes the DAC (CS4398) is transformer coupled,what to do about the inductance?
I have used the interconnects with my Benchmark DAC 1 whithout any problem(Heat).
Regards Åke
Old 30th November 2009, 07:26 PM   #6134
Tyimo is offline Tyimo  Hungary
Thanks Fishski13!
Old 30th November 2009, 09:04 PM   #6135
alazira is offline alazira  United States
alazira's Avatar
Hi Ryssen,
Do you know what the output impedance of the DAC is? If it is very high then the addition of capacitance may be creating a low pass filter. As suggested by juma I've been reading Borbely's jFet paper (http://www.borbelyaudio.com/adobe/ae599bor.pdf). It describes a type of distortion that may be relevant to you if you have a high source impedance coming in.
from Borbely
"As though the existence and size
of the input capacitance were not
enough, it is also voltage dependent,
which might cause distortion
in certain applications. Figures 10A
and 10B show the voltage dependence
of Ciss and Crss, respectively,
of the K170 JFET.
Depending on the excursion of
the input/output signal, you get a
capacitance modulation, and this
can cause distortion of the audio
signal. This shows up mostly when
you drive the circuit from a highsource
impedance."
Perhaps you can try lowering the jFet capacitance by either cascoding or increasing the source resistors (R1&R2)
Old 30th November 2009, 10:13 PM   #6136
Ryssen's Avatar
This is the trafo LL1517 http://www.canford.co.uk/ProductResources/ig/2735.pdf
It says,Secondarys in series(which i have) 600 ohm,that don seem so high.If it has anything to do with it it has 1k and 2,2nf in paralell,at secondary.
Regards Åke
Old 30th November 2009, 11:36 PM   #6137
Tripmaster's Avatar
Hi there
I am currently at page 176, only another 438 and counting!
I have built various chipamps over the last couple of years and now fancy having a go at Nelson's 'F'-series. I have heard that several versions can use the same unregulated power supply. Can I build one power supply to work with entire range? If not, which models are compatible with the supply below?
I am also trying to source an enclosure with a suitable heatsink.
modushop.biz
Would someone be kind enough to check the attached PDF and let me know which model would be suitable?
I will also be driving a pair of Brines FT-1600 Mk2 Speakers
Thanks for your help
Richard
My photostream: http://www.flickr.com/photos/59839778@N04/
Old 1st December 2009, 03:09 AM   #6138
5U seems missing in your attached file
You may be fine with the 160mm 4U, but I would choose the 200mm 5U-300mm
300mm has to my knowledge ONE whole heatsink on each side, the 400mm is split into double heatsinks, and not optimal, unless you build your own boards to suit, or hardwire
btw, someone mentioned that new models are coming, completly aluminium instead the soft steel used now
Old 1st December 2009, 07:50 AM   #6139
westend is offline westend  United States
As tinitus stated, the bigger, one-piece, heat sink is a better choice. There is a lot of heat being dissipated.
I built the F5 using these sinks: M&M metals 62430.
The case is an all aluminum DIY affair and I've noticed that the case, itself, is acting as a complimetary heat sink. I am able to hold my hand or forearm on the top of the heat sinks, indefinitely. For reference, the faceplate (pic attached) is 19" x 8".
Old 1st December 2009, 12:05 PM   #6140
Tripmaster's Avatar
Thanks for the info
It will be nice to have a thicker aluminium base plate to tap a thread. At around £200 the cases are not all that cheap, oh well...
Richard
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
rothay, hofer
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.18311 seconds (60.34% PHP - 39.66% MySQL) with 11 queries
