| Thread Tools | Search this Thread |
#6091 |
Hi Bobo,
In Chile everything is fine, Dollar is down so I can keep coming those big carton boxes full of the necessary to build the J2 and the Selectronic Triphon amplifier modules and compare them using the same supply which will use ECdesigns-s Charge Transfer supply and The Powerreg regulator from Teddy Pardo. I plan to test Altmann-s SPLIF amplifier topology on the Triphon. Appart that, we are preparing for presidential elections on December, which I hope will go without troubles...and the winter refuses to leave us... Au revoir, M
Cheapest horn speakers: https://picasaweb.google.com/lh/phot...eat=directlink |
#6092 | |
when one rail is open, the feedback resistor of the opposite half forces the corresponding Jfet to open , then there is no more bias on the facing mosfet. Thanks Jacco, i missed this aspect. Last edited by bobodioulasso; 25th November 2009 at 05:56 PM. |
#6093 |
And the feedback on the same side ?
Looks like Sponge Bob has killed another thread. |
#6094 |
On the same side?
Produces the opposite, ...but the rail is open on this side so...? |
#6095 |
No current from the open rail side is flowing through the load .
Neither any current from the opposite half (as stated upper) So the load sees no current at all. I do not really understand your question, Jacco. Or am i wrong somewhere? |
#6096 | |
#6097 |
#6098 |
Open as an open circuit.
#6099 |
#6100 |
As stated manytimes upper:
Jfets prefer to be thermal coupled ( close to eachother) It should be wise to count with cascoding in your lay out. Easy to strap if you do not use. (10% mains variations could bring the rails to 33 volts which is the very limit.) |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Jack C. |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.19551 seconds (65.92% PHP - 34.08% MySQL) with 11 queries |
