Old 21st November 2009, 02:25 AM   #6011
nigelwright7557's Avatar
Originally Posted by tinitus View Post
I dont think you should do that without monitoring bias at the same time
But now I talk about something Im not sure about, as I havent built my F5 yet
I usually turn the bias down to zero first then set the DC offset before attaching a speaker.
Then I put a multimeter across a source/emitter resistor and set it to just get rid of crossover distortion on the scope which is usually around 5mV across 0r22 resistors.
If its a new design i would then put a household iron on the heatsink and make sure the bias doesnt do anything silly as the ehatsink heats up.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 21st November 2009, 02:32 AM   #6012
My other channel (right) is working great. The one that is having the problem (left channel) was working great. It actually sound better the other (right) channel. I'm not sure but where all the values were 2.2k they were brought up to 2.21k ohms.
Anyways I'm wondering if there is a way to trouble shoot my problem. I can turn it on with the input isolated and doesn't seem to hurt anything. Is there a way to check for voltage drops to find out if the jfets are causing the issue or could it even be part of what is causing my problem?
Old 21st November 2009, 02:50 AM   #6013
tinitus is offline tinitus  Europe
Just read the F5 manual
You get zero DC when both bias trimpots are balanced
If you have DC problems, I suppose one half/side is not right
Or you may have very poorly matched Jfets
Or maybe too much heat from your soldering
Even if you think your soldering is perfect, you might be surpriced if you look through a magnifying glass
Or you may find a small bit of solder waste making a shorting
I check ALL my solder joints carefully with magnifying glass, and proper light
Just a thought
Old 21st November 2009, 04:45 PM   #6014
i have a problem guys. i need to the data sheet of my f4-1600 4 channels... my firend had it and it blowed a transistor, he took all of them off and to use it for parts... now i have it and need to change all of the transistors can any of u help me??
Old 21st November 2009, 06:52 PM   #6015
bobodioulasso's Avatar
Download the pdf there and you will have the F4 schematic
First Watt: Products: F4
Old 21st November 2009, 08:03 PM   #6016
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Oye Joselito,
este forum es para los amplificadores caseros de Nelson Pass, no para esos en coches, este de usted es un amplificador del coche.
Looks like Sponge Bob has killed another thread.
Old 21st November 2009, 08:11 PM   #6017
Cuantos lenguages puedes hablar?
Old 22nd November 2009, 12:47 AM   #6018
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Jacco is nuckin futz , in any case .
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 22nd November 2009, 01:07 AM   #6019
Audiofanatic's Avatar
Wink F5
Hi Jacco, dejate de eso hombre Help hem even met zijn F4
Back to topic.
"Bleuwater"
Perhaps one of the output transistors is tighter than the other? That way you'll have a difference in cooling the device which will give you DC offset.
Just my 2 cents.
Best regards,
Audiofanatic
Be nice to animals.
Old 22nd November 2009, 01:16 AM   #6020
alazira is offline alazira  United States
alazira's Avatar
Originally Posted by Zen Mod View Post
just trow them in , and follow biasing procedure .
instead of one IRF(P) pair - it's wise to use at least two pairs of laterals , because of xconductance ( lacking in laterals) .
all these questions are beaten to death in this thread ..... twice or trice .....
make it more fun - make two F5s with one supply - one with verticals , one with laterals; connect one to PSU and listen ..... change to other one and listen
use same gate stoppers for both iterations - varying them +/-50% you'll not hear difference .
Hi ZM
Please excuse me if this is a silly question, but can the mosfets share the gate (R13&R14) and source resistors (R11&R12) or do they each need their own? I was planning on trying other variations (i.e. 20R/100R feedback) but NP's comment has intrigued me.
Currently Active Users Viewing This Thread: 7 (5 members and 2 guests)
UKToecutter, zephyr, nick5, SOUND_Rays
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.42219 seconds (27.86% PHP - 72.14% MySQL) with 11 queries
