Old 20th November 2009, 05:00 PM   #6001
bobodioulasso's Avatar
Originally Posted by bluewater View Post
Would anyone have any input on why I would have 500mV pushing out my outputs on one of my channels?
Are you shure there is no dc at the input?
Old 20th November 2009, 08:48 PM   #6002
the input is isolated from anything and the two output transistor are cool to the touch.
Old 20th November 2009, 08:55 PM   #6003
CBRworm is offline CBRworm  United States
That can't be good. Touching a cold amp is like holding a dead fish.
To return to Oz we've fled the world with smiles and clenching jaws - SS
Old 20th November 2009, 09:28 PM   #6004
compressit's Avatar
Bluewater, have you confirmed that both pots are at zero and re started the bias process from scratch?
Old 20th November 2009, 09:57 PM   #6005
tinitus is offline tinitus  Europe
And prove sticks have been connected in the right place when adjusting?
Old 21st November 2009, 12:42 AM   #6006
thank you for all the reply's.
no I haven't tried starting from zero mostly because it was working fine before this happened. I not sure if starting with the pots is the right course just yet.
tinitus, what do you mean by sticks?
Old 21st November 2009, 01:05 AM   #6007
Oh, sorry
I wrote "prove" sticks, and it should have been "probe" sticks
Those things to connect multimeter to amp board
Isnt that what they are called?
What I was asking
Do you measure the right way?
Is multimeter used properly?
Connection point, meter setting etc.
Are your probe sticks in good condition?
I have to resolder mine frequently
Not the most reliable things
And sometimes a meter works fine with one setting and not with some other setting, cheap ones ofcourse, but thats what most of us can afford, but may not be completely reliable either
Old 21st November 2009, 01:14 AM   #6008
they work fine and are in good shape. When adjusting the dc offset I connected them to the output and the output ground.
Old 21st November 2009, 01:20 AM   #6009
I dont think you should do that without monitoring bias at the same time
As I understand it, its possible to "find" a bias a point where DC is low
But you cannot just turn bias pot to the lowest DC
It should be done carefully, bit by bit
And never turn bias pot only looking at DC
Output devices can go dead in a second without heatsink even getting hot
But now I talk about something Im not sure about, as I havent built my F5 yet
But I do remember to have done something similar, turning a trim pot without anything happening
Amp went dead before I realised I had been looking at the wrong meter setting
Old 21st November 2009, 01:23 AM   #6010
While adjusting the offset I had another multimeter monitoring the voltage drop on r11 or r12.
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.19916 seconds (66.86% PHP - 33.14% MySQL) with 11 queries
