| Thread Tools | Search this Thread |
#5981 |
As in bundled so that they touch eachother, like two smacking teabags ?
Looks like Sponge Bob has killed another thread. |
#5982 |
not politcally affiliated
and duct-taped to my neck to ease the pain from arching my neck
SemiSouth R085/R100A JFET available now DCB1/BiB #3 on order : SSHV2 Sign up Sheet/Payup Sheet Ends 2-26-2012 CLICK HERE |
#5983 |
#5984 |
I'm a tea-seholic, mea maxima culpa.
I bought these square tea-bags in GB last spring, attached to eachother as a string in the box. If i put two side-attached bags in a pot they stick like folding leaves and it takes long for the tea to reach prime time, i have to put them in one by one. Power resistors are like little heatsinks, they need plenty clearance to cool properly. Bundle them together and their temperature will skyrocket, despite having plenty power reserve.
Looks like Sponge Bob has killed another thread. Last edited by jacco vermeulen; 19th November 2009 at 08:16 PM. |
#5985 |
Passive Aggressive
An amp that will drive, if I recall, "2 Ohms without burping" probably is not having trouble with speakers or cables. I wish I knew that answer but my first thing to eliminate as a problem would be the speakers/cables.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#5986 |
Depending on wether Bluewater has wired or not the limiters.
In the second case, an intermittent short circuit could be lethal. I am thinking about a thin strand of copper at one end of the cable for instance. He said he replaced the channel which burnt again. So, i immagine the cause is external. ...Better to ask Bluewater if he uses limiters. |
#5987 |
24 Volt supply, with 16 volts quiescent across 16 ohms. I=V/R so that's 16/16 which is 1 amp. Watts = I*V so that is 1*16 which is 16 watts. That's under no signal conditions. Worst case is the FET turning on and putting 24 volts less the drain source saturation voltage. Lets go worst case and say 24 volts. Using the above that's 36 watts. The amp is AC coupled at the input however so that's not going to happen. You need to choose a resistor (data sheets !) that will dissipate around 20 watts (preferably a non inductive component too) in the conditions you require ie free space, or attached to a heatsink where you have calculated the temperature rise etc and know it is within the operating limits of the resistor. And my somewhat "unkind" last comment.If we take the power out (headphones) as say 20mw and the power input of the amp as 24 watts, then powerout/powerin * 100 gives an efficiency of 0.083% Draw your own conclusions on that one
#5988 |
#5989 |
The planet.
#5990 |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Jack C. |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.19100 seconds (61.17% PHP - 38.83% MySQL) with 11 queries |
