F5 power amplifier - Page 598 - diyAudio
Old 19th November 2009, 01:39 AM   #5971
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Default Somewhat off topic Headphone amp in service manual
I decided to build the headphone amp from the service manual, since the parts are minimal. It works just dandy, however the 50 watts of resistors making my 16ohm source resistor still run about 120c. The heatsink for the mosfet runs cool. Any idea what the ideal resistor wattage is here? Looks like a heatsink type for sure...
Salas Boards GB 2017#1 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2CBoards and transformers In stock PM for details
Old 19th November 2009, 03:28 AM   #5972
bobodioulasso's Avatar
Your resistor should dissipate 16 watts only.
Did you measure 16 volts across it?
Old 19th November 2009, 06:52 AM   #5973
I've replaced the one channel that burned out. I made sure my soldering was very good.
Every thing seemed great. Then the newly installed channel was starting to have distortion. I check the dc offset on the terminals and it was all the way up to 500mV!
The resistors on R11 and R12 were very low, under 30mV. I've hit a wall. This situation is very similar to before, when the same channel burned out when I messing with the pots trying to correct the problem. All new parts and pcb were installed. I would really appreciate any help.
Old 19th November 2009, 08:20 AM   #5974
i would suspect the speaker or it's cable.
Old 19th November 2009, 11:07 AM   #5975
Tea-Bag's Avatar
The measurements are exact to what's posted. Someone did their homework.
The 16 ohm resistor from source to ground just seems to need a be a large power resistor.
Old 19th November 2009, 11:50 AM   #5976
Some oscillation?
Old 19th November 2009, 05:41 PM   #5977
Beftus is offline Beftus  Netherlands
Beftus's Avatar
The 16 ohm resistor needs to be a power resistor, just as Nelson writes it in the text. Pity though he didn't specify a Watts rating for it. Nelson, could you shed some light onto this matter?
Old 19th November 2009, 05:47 PM   #5978
Mooly's Avatar
Just work it out
Quiescent is 16 watts dissipation.
With the FET fully on nearer 25 watts or more peak.
So a 20 watt resistor will be fine.
And for driving a pair of headphones that IMO is obscene, but there we go.
Old 19th November 2009, 07:27 PM   #5979
Tea-Bag's Avatar
Originally Posted by Mooly View Post
Just work it out
I was hoping for some help there.
I have 45 watts of sand-cast wirewounds bundled together, putting off an enourmous amount of heat. a Finned heatsink mountable seems the way to go, but what wattage? Right now just a little clip lead project to get an idea of the sound of the unit.
Old 19th November 2009, 07:34 PM   #5980
Let it get cold, short circuit the input to ground and see wether it heats as much. That is a way to check for oscillation.( unless you have a scope)
If there is less heat this way, the problem is : it oscillates.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright 1999-2017 diyAudio
