Old 16th November 2009, 01:48 PM   #5881
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by AndrewT View Post
Juma has given you a starter value.
Ignore or follow his suggestion.
The decision is your's.
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 16th November 2009, 02:02 PM   #5882
tinitus is online now tinitus  Europe
I happen to agree
Not the perfect choise
But all we really need is a curcuit safe enough to power up
It just have to work without burning
THEN we can talk about perfecting it further
And we may have to realise it may still burn eventually
I wouldnt leave it out of my sight fore quite a while
I suppose its name of the game
Lets just build it, and talk later
Old 16th November 2009, 02:20 PM   #5883
Hello
For me it does not make sense to change the orig design JET to V fet .Even Juma first draw for the higher power rail with JET now when all design done why should I trow it out all on the window and start again something copletly different ?
Thank you any way .
I go with out cascode .
I have the layout for that to .
Thanks one more time guys , it was kind to read your advise ! I have no need more these type of help.
Greets
Old 16th November 2009, 02:30 PM   #5884
udailey is offline udailey  United States
Passive Aggressive
Gab,
Your board does not make a lot of sense. You have these two rails coming out from center going left and right. They have two parallel lines connected by angles that look like mountains. If this is single sided... then you have simply created a plane going to the left and a plane to the right. So are the mountains just for looks or what is the point? Do you have any kind of silkscreen so we can see what you are trying to do? The schematic along with that board is not going to help a lot except that we can guess easily which are mosfets and which are resistors going to mosfets. Other than that its a bit confusing. Just to be clear I have no intention of diagnosing your FX-5 circuit as it is beyond me, but I am pretty sure that board is either designed for looks, making it confusing, or designed wrong.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 16th November 2009, 02:39 PM   #5885
I have never seen nothing but good behaviour in the PASS forum
Im sure its obvious why
Or maybe it isnt
Maybe it wont last forever
But please, lets try not to spoil it
Old 16th November 2009, 02:39 PM   #5886
Renron is offline Renron  United States
Renron's Avatar
Udailey,
Positive, HELPFUL, well thought out, informative, direct and concise.
Well Done, great post!
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 16th November 2009, 02:43 PM   #5887
bobodioulasso's Avatar
The fun of that story is that the regular F5 is a very good sounding proven design 100% warranted very simple to build without any headache.
Aren't you simply curious to listen to it?
Or are you smarter than Papa?
Not to forget that a distortion analyser should be helpfull to tweak the mods.
Old 16th November 2009, 02:43 PM   #5888
Passive Aggressive
Or maybe it isnt
Tinitus,
There was no maliciousness in my post whatsoever. None.
Uriah
Old 16th November 2009, 02:51 PM   #5889
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
What does concern me is that this whole matter regarding an up-rated F5 should have been split from the main F5 thread very early on.
To attempt to find anything regarding the F5 - as originally gifted by Nelson Pass - is like looking for a needle in a haystack....a haystack of almost 6000 postings!
Old 16th November 2009, 02:56 PM   #5890
Hello
The board was design by hand , there is no silkscreen unfortunately .
Sorry about that . The reason I wrote I want to stick the orig design !It take me hours to draw a layout like these by hand .
These is not a SECRET or something I just don't have any silkscreen .
You can find the schematic in the last couple page if you seriously interested .
For me it make sense , I DESIGN many working boards like these with out any software . And always work out fine .
I posted the cascoded the input before .But I will posted one more time and also the full schematic .
My orig question was : The cascode was design to 40V rail , now I go with lower voltage actually 24V rail .So if I want the cascode to work fine do I have to use lower value resistor to connect the cascode to the rail and to the ground or to the JET source.
Greets
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
