| Thread Tools | Search this Thread |
#5791 | |
No, not thermistors. I'm talking about a thermal switch that is wired into the primary side of the transformer that goes open if the temp gets above a certain level -- I think 75deg C in this case. It's for protection in case the amp starts overheating. Thanks, Steve |
#5792 | |
I was considering mounting an actual thermal switch to each heatsink that would open above 70C. If either one opened it would disconnect power from the amplifier. I had not worked out the exact details yet as to whether it would be directly wired, or if it would trigger a latching relay. I prefer to keep AC voltage away from my fingers, I also prefer not to need a small secondary power source for protection duties. I chose 70c ish because my heatsinks typically run in the mid 50's. My logic was that the only condition the heatsink would get that hot is if airflow was impeded or too much power was being dissapated indicating a fault. |
#5793 |
Hi CBRworm,
Yea, I installed one on each heatsink on an Aleph J that I built and they worked out good. But, I was just wondering if they are really necessary. I hate to have to tap more holes in my heatsinks just for those guys. Thanks, Steve |
#5794 |
I don't know if they are necessary. Ideally they will never be called to action. In my case I have the heatsinks on the inside and a slow, quiet fan moving air over them. If the fan was to stop for some reason, or if the amp was set on shag carpet instead of a hard surface - I could see it getting too hot.
I would say it is not necessary. Last edited by CBRworm; 13th November 2009 at 03:21 PM. |
#5795 |
Firstly on matching JFETs for the balanced version. If you were to use different source resistor values for the JFETs as I did, then you should match the Id of the JFET with the corresponding source resistor in place (i.e. not at Idss).
Zobel at the output would not work, as it only loads the amp at HF and not DC, which is what we want in this case. On thermal drift, you can improve drift stability by coupling all JFETs together to a common thermal ground (a piece of aluminium or even better a heatsink). You may of course use a pair of my Dual JFET heatsinks (see GB forum), but that might limit your PCB layout freedom. Toshiba Dual JFET Heatsink As to thermal switch, I do use them on my reference amp, and I have them mounted with thermal grease on the main heatsinks. Since smyslow has apparently built the X-version with floating X, maybe he can also share his experiences. Patrick Last edited by EUVL; 13th November 2009 at 04:14 PM. |
#5796 | |
Thank You Patrick I was ready to order the parts then I sow your post , so I canceled the order . I will match the JETs Idss and I will use the same value source resistor for all 4 place ! Do I use 10R or less is better? What is the purpose you use different feedback resistor value ? I see Smyslow use 4x100R . Yes I realized the Zobel wouldn't work in here . I just look up some AX schematic . So I will buy Caddock MP930 resistors .Probably with a small TO220 heat sink . Thank you one more time . Greets Jeno |
#5797 |
If you use 4x 10R for source resistors, then you should also use identical values for the feedback resistor, as you want the same close loop gain, I presume.
Patrick |
#5798 |
Thermal protection
Holton sells a speaker protection module with optional thermal protection Not sure how thats supposed to work Wonder if thermal protection could be incorporated into a softstart module |
#5799 |
Hey Tinitus,
Yes you can incorporate thermal protection in the soft start-etc. module. I have seen that approach taken. but, you still need a thermal switch to sense the temperature. Steve |
#5800 | |
http://www.national.com/an/AN/AN-1849.pdf Anyone heard from Troy recently? |
| Currently Active Users Viewing This Thread: 7 (6 members and 1 guests) | |
| zephyr, nick5, UKToecutter, Jack C. |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.20979 seconds (66.09% PHP - 33.91% MySQL) with 11 queries |
