Old 12th November 2009, 11:18 AM   #5751
Formerly Thanh1973
I could be totally wrong but I think there should be another reference to ground around the feed back loop like there is on the Aleph JX.
For some reason I don't feel comfortable with this circuit design.
Hopefully some one else here can look at it more critically than myself (I know nothing).
I will try and present another version that works for people to have a look at.
Old 12th November 2009, 11:24 AM   #5752
Patrick he built the first F5X I think more than a year a go . It is around at 120th page .
He use 16V rail power supp. Works fine .
I want to build a bit higher power .
I have some experience with the Aleph X , I built one .
One think is sure every step have to be made careful . Also not to be afraid .
I plan at first use lower V transformer to power it up jut to get some experience with the bias .I didn't built any regular F5 . So some experience would help to be more confident .
Greets
Old 12th November 2009, 11:30 AM   #5753
Formerly Thanh1973
Yes I know Patrick built it, and it worked, but he didn't seem too impressed with it.
Which suggests to me that something is not quite right.
Peter Daniel has built the standard version and he absolutely loves it.
So if implemented correctly the F5 X should be an improvement over the standard version not worse.
Hopefully Patrick, Peter and others might like to revisit this design to see if it cannot be improved further, or at least discuss why they feel it did not perform as expected.
Old 12th November 2009, 11:33 AM   #5754
I just posted that schematic because the schematic originally posted there is no ground at all .
Please take a look at smyslow picture posted from his working amp and the PC board next . Even Patrick used that as a reference when he built his F5X .
I also interested any new advise , the truth is after my knowledge only two F5X was built .
Surly that will not stop me to give a try .
Greets
Old 12th November 2009, 11:43 AM   #5755
Formerly Thanh1973
Yes you should go with this design.
I just want to make sure you get the best possible info and advice on this one.
One thing I dont like about it, is 4 trim pots to adjust bias and dc offset. This could be a nightmare trying to adjust.
If the Jfets are matched, I think you should be able to get away with two trim pots.
Anyway it would be nice to discuss this design a bit before you get into trouble with it.
Old 12th November 2009, 11:48 AM   #5756
bobodioulasso's Avatar
I remember of a Nelson's post about the subject in the early pages (farther than page 50). A search for it could be usefull. I have no time now but i will try later.
Old 12th November 2009, 11:52 AM   #5757
Please read Smyslow comment on both amp .
He built at first the regular F5 and after couple month he completed his X verizon .
To him the X sound better than the regular F5, it is improvement .
Also Patrick use protection 4PC BJT and extra 12PC resistor each channel.
I would like to to build mine exactly after the Smyslow amp .
To be honest not always easy to take people comment on the sound of the amp as a fact , I read someone built his amp after P Daniel's F5 and he wrote , he is not happy at all it has week bass etc .
Many time the result depend on the components we use , transformer size (Wattage) wires etc .
I think you know all these .
Please read Smyslow comment on his X-ed F5 . Just go back some 5 page or so .
Greets
Old 12th November 2009, 12:04 PM   #5758
Hello thanh
You probably right about the 4 trim pots but I think it will give you more possibility fine for adjustment , fine tuning .
After there is a possibility to replace them if we get the same value at each trim pot .Probably a lot depend on the well matched JETs mosfet(s)?
If you think only two people made the X verizon , so not much information out there .
But that not mean we can not get help from some expert guy .
Old 12th November 2009, 12:15 PM   #5759
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by osscar View Post
irfp9240 from Vishay and 240 from International Rectifier (IR).
Read this : VISHAY FORMERLY INTERNATIONAL RECTIFIER|IRFP240|MOSFET, N TO-247 | Farnell United Kingdom
Vishay bought the power semiconductor branch from IR in 2007.
(the two companies have been fighting over it in court ever since, reached an agreement with some alterations of the initial contract just a couple of months ago)
So: different label, but exact same deal.
Looks like Sponge Bob has killed another thread.
Old 12th November 2009, 12:31 PM   #5760
flg is offline flg  United States
flg's Avatar
Originally Posted by jacco vermeulen View Post
...Vishay bought the power semiconductor branch from IR in 2007.
IR sold portions of their older, lower profit margin, MOSFET bis to Vishay. Not their "power semiconductor branch". If you noticed, Vishay instantly raised the price on all of those products by a buck or two
But, your right "different label, but exact same deal"
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Currently Active Users Viewing This Thread: 10 (9 members and 1 guests)
dux, Dennis Hui, lhquam, massimo, UKToecutter, njepitt, jernejc
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.18575 seconds (65.81% PHP - 34.19% MySQL) with 11 queries
