Old 10th November 2009, 08:57 PM   #5711
Bobodioulasso
For the normal F5X I do not have transformers (I want to use what I have at home if is possible), also around 24V rail i read the power mosfet tend to sound better . I don't know if these true about the Toshiba devise or just IRPF type . It would be a waste use such a large heat (25Kg not 25Lb , I wrote a mistake in another post about the size of the heat sink) it was design to a Aleph2 for the simple F5X .These not because I will need 100W monster POWER . I'm interested to get a great amp not a big monster . The only reason I want to use what I have at hand already . A great Plitron transformer like mine 1.5KVA 250bucks . If the higher power F5X not possible, unfortunately I will have to go with the higher power F5 but I'd like the X topology .
One more time everything I have at home to go with higher power verizon if these would be possible !
So why not to use all the parts I have already?
If is possible high power F5X I will post some pic. from the material I have . Now I charge my battery for my camera .
Greets
Old 10th November 2009, 08:59 PM   #5712
udailey is offline udailey  United States
Passive Aggressive
Will be fun to watch your build. Thread is getting interesting these last few days again!
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 10th November 2009, 09:47 PM   #5713
I just want to post some picture from those parts I have at hand .
The heat sink 15" tall .I think that can handle even 100W power . Over 25 kg the enclosure with out any parts .The transformer 1.5KVA from Plitron it would give 24V after rectification (I use it in my Aleph X with 7A/ channel .
I have the matched Toshiba mosfet enough to build even a 100W amplifier .
My question why would not use all these parts to get the best out of them ?
Of course I take any advise . I will try to build use the parts .
To set up the bias probably I would try to at firs a lower Voltage smaller transformer . Just to get some experience not to burn my expensive power mosfet .
Only think I'm not sure if I have to adjust any resistor because the higher Voltage rail?
I will go on and try .
At first I thought to try the AlephJX but I already have a SE Aleph X .
These would be more interesting if I can manage to build it .
Greets
Old 10th November 2009, 09:48 PM   #5714
tinitus is offline tinitus  Europe
Originally Posted by jacco vermeulen View Post
Patrick picked 16Vdc rails because that's 12Vac rectified.
Maybe first we should agree that when referring to 24V rails we would expect it to be 24Vdc, from 18V trafo
24V trafo should give you 33V rails
I suppose thats what you mean
Impressive collection you have
Just a small remark of caution
Those expencive mosfets may be highly sensitive to statics
And to place them on a highly static plaid like you show in your post, that might not be the best to do
I dont know so much about that issue, but that I would avoid
Old 10th November 2009, 10:01 PM   #5715
Yes Tinitus you totally right .
18-0-18VAC transformer 24VDC . 33VDC rails that would be a big furnace .
Sorry if I wasn't clear enough with these information .
Greets
Old 10th November 2009, 10:03 PM   #5716
mstr is offline mstr  Austria
Hi Gaborbela,
I´m not sure if your 2SK1528/2SJ200 will handle the power dissipation at higher voltage, they seem to have a much smaller package than the SK1530/SJ201, which have been used by Uwe(smyslow). His output devices are running quite hot, and if I remember correctly he uses slightly increased bias (~1.6A) at reduced voltage. But as you said, probably you get rid of the heat by using more devices in parallel.
Just a question: why don´t you try the Aleph J-X? PCB are available, and this project seems to create a real monster amplifier, with up to 12 FETs per channel.
Hopefully I will build this amp during Xmas holidays, if anyone has compared the F5 to the AJ-X or AJ, please be so kind and report your results! (sorry for hijacking this F5 thread )
Old 10th November 2009, 10:07 PM   #5717
Impressive heatsinks!
Sorry, you answered the question about the AJ-X while I was still collecting the right words for this query
Old 10th November 2009, 10:32 PM   #5718
Tinitus that plaid 100% wool not supposed to be highly statics. But you right I must be more careful with those mosfet(s)
My Toshiba mosfet has the same size like the IRFP240 type .
The reason I would use 3 pair in parallel to get read of the heat , I think 3 of these can handle more power than one or may be the two of the bigger brother .
If you take a look at the data not much the difference between the two device .
I will try I hope everything will work out fine .
Also I wait to get some advise from expert guys .
I would like to use what I already have !
Greets
Old 10th November 2009, 10:41 PM   #5719
nigelwright7557's Avatar
[QUOTE=gaborbela;1976314
Greets[/QUOTE]
Great care needs to be taken with the bias.
Some bias adjusts are very touchy and can go from no bias to a hefty bias in a slight touch.
It might be worth just putting in one pair of MOSFETs until you are sure you know what you are doing. Then put the bias back to zero and put in the remaining MOSFET's then tweak the bais back up again.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 10th November 2009, 10:58 PM   #5720
And remember to drain the supply with a big resistor before disassembling/assembling
Its usually good practice to power up supply and measure before connecting amp curcuit
After this its good to drain supply before connecting it to amp
I usually repeat it a couple of times until it measures zero
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
rothay, hofer
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.21206 seconds (67.64% PHP - 32.36% MySQL) with 11 queries
