Old 9th November 2009, 06:24 PM   #5681
CBRworm is offline CBRworm  United States
Nice Pics MSTR, your first F5 is much nicer than my first F5.
Here's a pic of my first functional channel. It has since evolved into a chassis and grew a brother.
Old 9th November 2009, 06:38 PM   #5682
mstr is offline mstr  Austria
Originally Posted by yildiray View Post
Way to go mstr!!
i m very jealous can i ask to you needless question,where did you buy your eurocard board? from rothelectronic?
Thanks!
I think those boards came from farnell, but I´m not shure because I had them in my drawer for some years, waiting for a project.
We soldered them up-side-down, just to make sure to have access to all nodes after installation of the board. This technique has proven very practical for first measurements.
Old 9th November 2009, 06:50 PM   #5683
yildiray's Avatar
actually you right,this's ideal for measurement.i will do this project ıf i can save money but probably i will use peters kits
have a good listen,regards
Sinestesia
Old 9th November 2009, 06:52 PM   #5684
Patrick (EUVL) and others, can the Balanced F5 be built with 2SK1058/2SJ162 outputs and can they withstand a bias current of 4Amps; or what about the IRFP 240/9240 devices, without thermistors?
Sam
Old 9th November 2009, 07:13 PM   #5685
Cool, I really like this sort of engineering!
You are far ahead, the brother of my F5 is still under construction, because after the last update I did some mistake and reversed the PSU polarity at one channel... It´s really a pain to let the smoke out of caddock resistors
Old 9th November 2009, 08:00 PM   #5686
ewww. Good luck getting the smoke back in. . .
Old 10th November 2009, 12:02 AM   #5687
smyslow is offline smyslow  Europe
Originally Posted by P. Lambda View Post
I am planning on building a balanced F5. Is your bias 1.6A total for each channel or is that for each pc board ?
As Andrew wrote, it's 1.6A for each pcb I used and therefore 3.2A for each channel.
Uwe
Old 10th November 2009, 12:17 AM   #5688
Hi Sam,
of course you can use IRFP240/9240. But not with a continuous drain current of 4A! If your rail voltages are let's say +/-24V you get a power dissipation of 24V x 4A = 96W for each device. This is too much! The power dissipation for each device should not be higher then 30W.
Uwe
Old 10th November 2009, 03:58 AM   #5689
Smyslow, thanks for your reply. So I assume that IRFP240/9240 outputs can be used safely without thermistors. However, I was looking at Patrick's (EUVL) schematic which shows rails of 16 volts and he did mention 4Amps bias with Toshiba devices.
I wonder where the 'sweet spot' lies for each of these device pairs when used in a balanced F5: 2SK1058/2SJ162, IRFP 240/9240?
Sam
Old 10th November 2009, 04:20 AM   #5690
jackinnj's Avatar
What is this thing that DIYr's have w beer?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Jack C.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.19721 seconds (53.32% PHP - 46.68% MySQL) with 11 queries
