| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Thread Tools |
#5671 |
was nice to come home and read
#5672 |
I have question.Is transformer vith 19,8v-0v-19,8v,ok for F5 ?
#5673 | |
BTW, here is a pic of my current setup. As CD source I use a Sony CDP 337 ESD and the speakers comes from Dynaudio. On top of the CDP you see a pcb with the single to balanced converter, which is my present diy toy ![]() Uwe |
#5674 |
The one and only
#5675 |
Mr. Pass many thanks for your help .
That mean I will try another option to . I did lot of research on these topic .There are many different possibility .Zener diode to the ground , resistor to the ground , resistor the Source of the JET etc . Greets |
#5676 |
Smyslow very nice amp .
Well done . Greets |
#5677 |
Smyslow,
I am planning on building a balanced F5. Is your bias 1.6A total for each channel or is that for each pc board ? |
#5678 |
the bias current flows through each and every output device.
In a pair of push/pull devices (standard F5) each will pass bias current. The PSU will supply the bias current. A balanced set up will pass the bias current through every output device. The PSU will supply double the device current.
regards Andrew T. |
#5679 | |
Hi all, as Uwe suggested, there are some nice pics from our first F5 building session which we want to share with you... We built this monster in order to get first impressions of the sound and stability, so please ignore the "Frankenstein" look of this amp. ![]() Funny sidenote: Ignoring the strange (some may say "technical") look, the sound is really great, so I decided to keep this monster in my livingroom until now... althrough the WAF-factor is quite low ![]() My current setup is a combination of F5, fed by a D1-clone (TDA1541S1 to first stage of D1, followed by B1 used as output buffer), and the sound is really amazing! Thanks to all of you for your contributions to this project, thanks to EUVL for his Toshiba-based F5 schematic, and special thanks to the Master himself for sharing this wounderful design with us & keepin' the DIY spirit alive! greets, Michael |
#5680 |
Way to go mstr!!
i m very jealous can i ask to you needless question,where did you buy your eurocard board? from rothelectronic?
Sinestesia
| Currently Active Users Viewing This Thread: 4 (2 members and 2 guests) | |
| compressit, dkrbo |
| Thread Tools | |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 7 | 23rd October 2004 04:09 AM |
| Page generated in 0.10820389 seconds (70.82% PHP - 29.18% MySQL) with 11 queries |
