Old 3rd November 2009, 08:32 PM   #5551
westend is offline westend  United States
Originally Posted by alazira View Post
Set the bias pots to zero. On CVillers' board he has legs 2&3 together which means you turn completely counter clockwise to zero it. On Peter Daniel's board he has pins 1&2 together which means you start with the pot turned completely clockwise and bias it by turning it counter-clockwise.
This was my understanding, also, regarding the trim pots, until I fired the amp for the first time. I am using C Villers boards and the Bourns 5K trimpots. If the trimmers are turned counter-clockwise, full current will be delivered to the circuit. The trimmers must be turned clockwise to zero the current You can read the gory details Here. Fortunately, my components survived this misstep and the amp is settling in well.
Old 3rd November 2009, 08:45 PM   #5552
Beftus is offline Beftus  Netherlands
Beftus's Avatar
You must have skipped this bit in the F5 manual:
Before applying power to the amplifier, you will want to set the values of P1 and P2 to their minimum. Verify this with an ohmmeter.
Old 3rd November 2009, 08:49 PM   #5553
alazira is offline alazira  United States
alazira's Avatar
Originally Posted by Russellc View Post
Is it running yet? Thanks for the post.
russellc
I had it running for a few days before the discussion of R1&R2 wattage ratings came up. Initially I thought I had .33w resistors there and had played it at volume so was surprised that they didn't fail. However, I rechecked and they are actually 1watt HOLCO resistors.
It's a PTP that I used for practice before I use my "better" caddock parts, and to see if I needed R9. So for those here with a Lightspeed Attenuator and F5 (I see quite a few here who frequent both threads), you can probably make it without R9. Just one less resistor in the pathway
Not terribly elegant looking. None of my stuff turns out that way. More like a caveman put it together I have PD's boards and may use them as I built it to be interchangable with his formfactor.
I thought why not make everything point-to-point, even the bridge diode.
Old 3rd November 2009, 09:01 PM   #5554
tinitus is offline tinitus  Europe
According to F5 manual R9/10 are fore safety reasons to minimize any problems with parasitic problems from a connected source
You know that too, Im sure
But Im not sure its safe to be that categorical regarding the Lightspeed
I suppose it would very much depend on the individual build and setup
Or maybe even the signal source before the preamp
btw, I got my Jfets today
Old 3rd November 2009, 09:01 PM   #5555
alazira's Avatar
Here I have pins 2&3 shorted, turned completely clockwise.
Maybe I'm remembering incorrectly. I'll check when I get home from work.
Old 3rd November 2009, 09:07 PM   #5556
alazira's Avatar
I didn't know R9 if for safety. If it is I'll put it in the final build.
You're right about differing systems, so that's why I used the politicians "probably", but should have been more clear. I'm using a simple setup of CD player - LSA - F5.
Old 3rd November 2009, 09:12 PM   #5557
How is this done in circuit? (I've already soldered them in place.)
Russellc
Old 3rd November 2009, 09:14 PM   #5558
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
alazaria,
cool looking p2p build. It looks like a diyselfer built it.
As long as it didn't catch fire, good listening!
SemiSouth R085/R100A JFET available now
DCB1/BiB #3 on order : SSHV2 Sign up Sheet/Payup Sheet Ends 2-26-2012 CLICK HERE
Old 3rd November 2009, 09:16 PM   #5559
As I have the Daniels boards, I am waiting for your response!
Russellc
Old 3rd November 2009, 09:17 PM   #5560
Right, I just checked, to be sure
R9 is precaution against the parasitics
R10 is safety reference grounding, when no signal connected
My humble guess about R9 is that it may sound ok without R9, and you may still have some oscillation or whatever without knowing, until it some day goes down without any warning
I wouldnt mess with those
Just a guess
Heavy looking amp your building
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
olegdt, jppaigle
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.18512 seconds (61.75% PHP - 38.25% MySQL) with 11 queries
