| Thread Tools | Search this Thread |
#5541 |
I used 2 of his 10.080 x 7 heatsinks for a stereo set. The fins were already vertical.
I found them to be more than sufficient for my F5 which has a pretty good amount of open air around it in an air conditioned room. I think BarredBoss might be a vendor here with a subforum. |
#5542 | |
See post 4935 |
#5543 |
Temperature Coefficient = Tempco= TC
TC for a resistor is in ppm/C, unit of the Temperature Coefficient for a MOSFET is mV/degree, as in : mV change per degree. The F5 is biased at 1.3A, you can find the Tempco at that current level from the set of curves in the graph. TC of a single device is not interesting, the F5 output stage is not a single device but a "complementary" pair. To compare the thermal runaway of different pairs requires determining TC for the entire output stage. (it's when you look at the curves of the Bad Bad IRFP9240 when things become interesting) |
#5544 | |
Ok, lets try it then Please point out the FIGURE ?. we should be looking at ? http://www.oup.com/us/pdf/microcircu...s/IRFP9240.pdf To me it seems some curves are going opposite way of what I would expect, which confuses me Last edited by tinitus; 3rd November 2009 at 12:37 PM. |
#5545 |
Figure 7 is the Vgs-Id graph.
The famous hump IRF P-channel has Zero TC at Id=2A, TC is less than 2mV/degree at a drain current of 1.3 Amp (Zero TC doesn't happen for the FQA12P20 untill Id reaches 12 Amps, 2SJ201 even has to go beyond the graph axis limit to make ends meet) Last edited by jacco vermeulen; 3rd November 2009 at 02:12 PM. |
#5546 | |
BBQs.... Russellc |
#5547 |
russellc |
#5548 | |
But he 150 degree and 25 ditto crosses around the point you mention Is that what you point at, thermal instability Nelson says its more reluctant to thermal runaway But you seem to conclude that the Toshiba might be worth the exstra cost That it should be considere Thats really all I wanted to know Thanks Jacco |
#5549 | |
| Currently Active Users Viewing This Thread: 4 (3 members and 1 guests) | |
| rothay, hofer |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.18402 seconds (64.22% PHP - 35.78% MySQL) with 11 queries |
