| Thread Tools | Search this Thread |
#5531 |
Formerly Thanh1973
Hi alazira
what is your question specifically? |
#5532 | |
The same goes for lower feedback network (R8, R6 and R2). Got it? |
#5533 | |
Thank you for taking the time to clarify that for me. ![]() So it doesn't matter if a single 50R or paralleled 100R is used. Can I assume this formula also applies to the reduced feedback model of 20R/100R? Garrett |
#5534 |
Seems like there could still be good reason to use IR devices
Looking at Toshibas they have gate-source voltage(vgss) +/-20V, which is similar to the IR devices Fairchild is +/-30V, which also has higher thermal resistance too, if I understand it Cant find anything on thermal resistance on the Toshiba But it seems the one available is with "Y" rating, which has the higher Vgs-off voltage Does this again mean its much less interesting Am I on right track, or ?
#5535 | |
The formula is Ohms Law (Google that too). But you can't use 100R/20R just like that. Changing 10R to 20R will change Id of JFETs and other parameters of the circuit consequentially. Visit Erno Borbely's site, there are good articles on "how JFETs work". |
#5536 |
#5537 |
Ok
I tried that, but dont really understand what it is I see on those graphs Other than FQA19N20C and Toshibas are look alikes, and only the IRFP are different Anyway, the Toshibas available are as said the Y types with higher OFF voltage To me, the Toshibas were said to be an option because they should be easier to drive, with the single Jfet Which to me means they should have lower OFF voltage, but it seems they really doesnt Besides, we have worked out how to do the cascode, which I suppose makes it easier to drive multiple outputs Or was the cascode just to make the Jfets take the raised supply voltage better, getting less hot Or does it work both ways I think Im a bit confused now |
#5538 |
Formerly Thanh1973
The cascode is for the jfet to run at higher power supply voltages
#5539 | |
Formerly Thanh1973
However the testing conditions are different Vds =10V for toshiba and Vds =40V for fairchild. I have no idea how sensitive the results are to Vds. Last edited by Melon Head; 3rd November 2009 at 01:46 AM. |
#5540 |
I've searched for every term I can think of to see if anyone has used heatsinkusa.com/eBay's BarredBoss heatsinks with the F5.
Has anyone used his heatsinks? What size did you end up using for proper cooling? I think my enclosure solution is using a Par-Metal Series 10 enclosure with the side panels being replaced with heatsinks. Also, since BarredBoss' heatsinks are extrusions, should I cut the heatsinks to mount with the fins vertically? Or should I used them in their natural horizontal state? |
| Currently Active Users Viewing This Thread: 5 (4 members and 1 guests) | |
| extrip, arche13, brainf, c_door |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.19054 seconds (61.88% PHP - 38.12% MySQL) with 11 queries |
