| Thread Tools | Search this Thread |
#5501 |
Careful, it may be a bit tricky to assemble, and do work on
Takes practice Anyway, a very tall box design with F5 would result in the upper half of the box being empty, which seems like waste to me Last edited by tinitus; 2nd November 2009 at 12:31 AM. |
#5502 | |
It is far too low for 4ohm speakers played loud. If your amp blows up, or takes out your speakers, because you deleted the thermistors, then you deserve all you get.
regards Andrew T. |
#5503 |
#5504 |
Anyone know if the Large gold heat sinks over on the Apex thread in vendors forum would work for F-5?
Russellc |
#5505 |
Russell,
if you mean the $20 each RF heatsink, the best you can expect is 0.50C/W Or 2 times 0.60C/W, the equivalent of 0.30C/W, if you saw the goldy locks in half. The densely spaced ribs make it a low efficiency heatsink for heights above 6" Last edited by jacco vermeulen; 2nd November 2009 at 03:22 PM. |
#5506 | |
Zen, BOZ, BOZ-J, BLS, B1, Mini-A, Audio Sector NOS DAC, Gain Clone, F5, CAT5 Speaker Cable, DIY Allen Wright ICs, MOX II |
#5507 |
I am using some Hammond 159ZL chokes for the CLC power supply. With air core inductors I have read that the inductors should be mounted as far away from each other as possible (and/or at 90deg angles to each other) to minimize magnetic coupling.
When using the iron core Hammond chokes, is mounting proximity still an issue? Or, is it not that significant since more of the magnetic field will be concentrated atthe iron core? Thanks, Steve |
#5508 |
They are 170x250mm
Yes, 2 pr channel ought to work I would prefer more like 4 pr channel But will it still be a bargain? Last edited by tinitus; 2nd November 2009 at 05:34 PM. |
#5509 | |
The circuit of Figure 5 illustrates the basics and does in fact work, but has a tendency toward instability ...and the bias drifts with temperature, requiring a lengthy adjustment period. .... This allows adjustment of the output stage bias current and also the output DC offset. We can stop here, and the amplifier will be fully functional. The remaining additions will enhance temperature tracking and provide for output current limiting. |
#5510 | |
If the heatsinking is designed for worst case condition as Pass would do, then the stability with temperature brought about by adopting the full thermistor compensated circuit is neither a problem nor a necessity , just a time saving exercise.
regards Andrew T. |
| Currently Active Users Viewing This Thread: 4 (3 members and 1 guests) | |
| Oreda, ce, unixdeveloper |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.19723 seconds (64.40% PHP - 35.60% MySQL) with 11 queries |
