F5 power amplifier
F5 power amplifier
Old 30th October 2009, 02:01 PM   #5471
juma is offline juma  Germany
juma's Avatar
There is a very good reason for 2W resistors in that position.
R1 and R2 are part of the feedback network and they see as much as one sixth (16,67%) of amp's output voltage which is 20V peak (max. value).
20V / 6 = 3.33V
Power dissipated on each of those resistors = (3.33 * 3.33) / 10 = 1.11 W (peak).
1/4W is OK only if you don't listen to your amp too loud.
Old 30th October 2009, 02:28 PM   #5472
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
Originally Posted by Russellc View Post
I inquired about this as well. My parts were one of the Tech-DIY kits, and the smaller Peter Daniels boards required standing up many or the resistors. R1 and R2 were 2 watt resistors that were so large I had a little difficulty getting them in.
In discussing this with Peter, he told me he had no problems with 1/4 watt in that position, and he should know.
Trace the current back -- all you will have is a bunch of burned out 1/4W resistors.
Old 30th October 2009, 04:16 PM   #5473
Russellc is offline Russellc  United States
F5 power amplifier
20V / 6 = 3.33V
I installed the 2 watt blue resistors that came with the kit. Paul Daniels said he uses 1/4 watt in that position with no problems. Maybe just lucky, but as many boards as he's sold with that advice, you'd think he would have had at least one person tell him otherwise.
Anywho, I installed the 2 watt resistors that came with the kit.....
Russellc
Old 30th October 2009, 04:27 PM   #5474
CBRworm is offline CBRworm  United States
I also used the 2 watt resistors in those positions. It seems like they can see a fair amount of current, and I tend to push things a bit beyond the design specs.
Question for anyone who has built both, how audible is the difference between the Fairchild and IRF P channel MOSFETs?
I saw somewhere a couple hundred pages earlier in this thread that someone was thinking of using the Renesas/Hitachi MOSFETs - did that ever get built?
I am curious with the fairchild parts going away if their is a better substitute for the output devices? I am curious to hear about tested replacements as opposed to simulated replacements.
Old 30th October 2009, 04:30 PM   #5475
F5 power amplifier
By the way, I sent an email a couple days ago and today sent a PM about
2 missing bourns pots in the kits I received, did you get either?
Know your busy
Russellc
Old 30th October 2009, 04:31 PM   #5476
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
F5 power amplifier
In case of raised voltage/power it seems like it could be an issue
Nice to know
Nelson mentioned slightly bigger source resistors
Maybe thats what he meant to say
Old 30th October 2009, 04:33 PM   #5477
F5 power amplifier
I bought both outputs, just in case. (Fairchild and IRF) It will be a while before I could give an opinion. I am going to build with the IRF devices. It is said they are slightly warmer, I'm betting the difference is trivial.
Russellc
Old 30th October 2009, 04:47 PM   #5478
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Toshiba J618+K3497
http://www.semicon.toshiba.co.jp/doc...eet_090929.pdf
http://www.semicon.toshiba.co.jp/doc...eet_090127.pdf
Groupy-B at DK for +100 each at $2/pc to get 'm.
Old 30th October 2009, 04:55 PM   #5479
F5 power amplifier
Nelson mentioned a pot referencing source pin to ground, to adjust sweet spot
I take it "source pin" is referenced to Jfet
Is it something like this
Old 30th October 2009, 08:44 PM   #5480
Melon Head is offline Melon Head  Australia
Banned
Originally Posted by jacco vermeulen View Post
I can't read japanese.
You could also try
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
